clutch problem help!!!!!!!!!!!!!!!!
Old Dec 4, 2006 | 04:58 PM
sdboostin111's Avatar
Default clutch problem help!!!!!!!!!!!!!!!!
ok installed my new block and clutch (act stage 3 6 puck) ,i still havent satrted the car yet ,but i ran into a problem,my clutch pedal goes down to the floor,and when i put the car in first gear it still rolls .so the clutch is ingaged so would anyone know why????????
Old Dec 4, 2006 | 08:04 PM
anyone????help plzzzz
Old Dec 4, 2006 | 10:46 PM
fastyouth1313's Avatar
Default Re: (sdboostin111)
its rolls on a flat surface? sounds like you need to adjust the clutch cable. under the pedal or going into the trans.
Old Dec 5, 2006 | 07:42 AM
the car rolls when its in gear,and its not the cable ot the pedal because i adjusted it all the way
Old Dec 5, 2006 | 07:48 AM
RTW DC2R's Avatar
Default Re: clutch problem help!!!!!!!!!!!!!!!! (sdboostin111)
if the clutch pedal goes to the floor, something isnt connected right or you need to bleed it. check the shift fork/slave connection and make sure the ball from the slave didnt come out of the fork.
leono
Oct 14, 2005 09:16 AM
Ataraxia
Jun 22, 2004 05:23 PM
civic_sir94
Dec 1, 2002 10:42 AM
E-AT_me
Nov 23, 2001 02:55 PM
Chip398193
Aug 31, 2001 03:54 AM
