Clutch slipping???? (video inside)
Old Jan 12, 2016 | 04:51 AM
PR8urVtec's Avatar
Default Clutch slipping???? (video inside)
I can't tell if my clutch is slipping or not. I think it is. The video shows a 1-3rd gear pull. Seems like it's slipping in second gear around 7000rpm. I did smell metallic but I was braking with my brakes from 100mph but not slamming on them.
LS/VTEC Turbo with a LS transmission and 205/40/R17 tire size.
Don't pay attention to the a/f gauge. It crapped out on me earlier that day. Innovative or Bosch widebands seem to go bad easy.
Old Jan 12, 2016 | 05:32 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Clutch slipping???? (video inside)
Doesn't look like it to me. Every one I have had slip from overpowering it will instantly hit the rev limiter after it reaches whatever RPM it starts slipping at under WOT conditions.
Old Jan 12, 2016 | 05:42 AM
PR8urVtec's Avatar
Cool. I was hoping you would reply. I trust your opinion as you and a few others have given me sound advice before.
Welp, if the clutch is holding then I guess it's on to stickier tires and more power.
I looked at a RPM vs Speed chart for B series transmissions and the MPH seems to check out with 8000rpm with a LS. Just wanted to get some opinions.
Old Jan 12, 2016 | 06:07 AM
m4xwellmurd3r's Avatar
also, afaik, if your clutch slips it will always slip at the rpm where it slips. Tires tend to slip when they hit a certain torque value based on gearing multiplication, where the clutch isn't subject to the transmission torque multiplication so they will always slip at a certain RPM.
Old Jan 12, 2016 | 06:15 AM
PR8urVtec's Avatar
Good to know. Thanks for that insight.
Old Jan 12, 2016 | 07:41 AM
DO IT ON ALL FOURS
You are welcome! And yes, maxwellmuder expanded on my poorly explained slip conditions; that has been my exact experience as he stated. Sorry, I was in a hurry LOL!
Old Jan 19, 2016 | 10:03 AM
PR8urVtec's Avatar
Welp, I took the car out to the local spot here in NOLA and the clutch is toast lol. Maybe when it gets hot or maybe I have oil leaking or something.
I did this race. I had a passenger, damn near bald tires, didn't launch the car at all, and missed third so it took a second to get in gear. But when I get it in gear you see how it walks the MS3. I also need to setup BBG and launch control. Overall I'm happy with it for 300hp @ 9.5psi. Don't mind the wideband reading. The sensor took a dump on me a few nights before. Tired of the Bosch widebands going bad.
And then the MS3 and I made a u-turn and went again. I hit 2nd gear and my MPH stayed at 40mph and the revs flew up with a metallic smell after. Swapping to a GSR and ITR FD w/ LSD and also adding a new clutch.
I'll edit the other video and show the slipping.
Old Jan 19, 2016 | 11:36 AM
DO IT ON ALL FOURS
In the original video in your original post it doesn't show the MPH very well... with that being said, you having a modified car it should rack out the RPM much faster when it is slipping under WOT conditions or you will get a sever rev hang effect, which I see neither of those. Check out this videos for comparison - first video is fast reving, second is rev hang. Both are indication of a slipping clutch.
I am not saying your clutch absolutely isn't slipping especially since the smell is there, just by the current videos I don't see it. Maybe a new video will shed some light on things. In the second gear run the engine flutters a bit exactly like it does when the tires loose traction. The higher in the gears you go the more pronounced the slipping will become.
Old Jan 19, 2016 | 01:00 PM
PR8urVtec's Avatar
Ok. I will post the second video when I get home from work. I'll try to make it bright so the gauges are clear to see.
Old Jan 19, 2016 | 03:01 PM
PR8urVtec's Avatar
Here is a slow motion of 1st and 2nd. Speedometer sticks at 40mph all of second. I made it as bright as possible. Hope this helps.
Here is real time.
Old Jan 20, 2016 | 11:38 AM
PR8urVtec's Avatar
https://youtu.be/ijhrDgxRweM
https://youtu.be/wg0cv-vkBR8
Check out the 2 short videos I posted.
Rickdogg
Jul 31, 2011 01:24 PM
civicxxxb16a
Oct 5, 2008 05:46 AM
MisterHYBRID
Sep 27, 2002 03:50 PM
illusion
Apr 17, 2002 08:06 PM
976
Jul 18, 2001 11:24 AM
