I REALLY NEED HELP WITH MY CLUTCH
I REALLY NEED HELP WITH MY CLUTCH...plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz zzzzzzzzzzzzzzzzzz help
IT HAS BEEN LEAKING BROWNISH TYPE OF LIQUID INSIDE THE CAR UNDER THE CARPET...I REALLY NEED HELP ON WHAT I SHOULD DO OR WHAT IS WRONG WITH IT..WHEN I PUSH THE CUTCH PEDAL DOWN IT DOES NOT COME BACK UP UNLESS I PULL IT...MAYBE THE SEAL IS BROKEN BUT I DO NOT KNOW IF IT IS THE MASTER CYLINDER THAT IS LEAKING OR THE SLAVE.....PLZZZ HELP IF CAN.... THX FOR READING.
Re: I REALLY NEED HELP WITH MY CLUTCH...plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz zzzzzzzzzzzzzzzzzz
That could be either the Clutch or Brake Master Cylinder (both in the same vicinity). Because you've got an additional issue, I suspect it's the Clutch master Cylinder that's giving you fits.
P
P
definately a clutch master cylinder needs replacing...
P_ ole buddy the brake master would not leak inside the car, the booster has a lip on it so brake fluid can no longer get inside the booster and ruin it ,, if brake master leaks it would show below master cylinder on firewall
Re: (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">...another entry for the notebook. believe it or not, I was thinking of non-power assist brakes. Go figure
P</TD></TR></TABLE>
Yo P-- u are showing your age amigo
P</TD></TR></TABLE>
ozh_hawaiian
12-03-2011 03:28 PM
I Like Hondas
03-20-2006 10:25 AM
