clutch making noise?
Old Apr 20, 2004 | 03:33 PM
94B18B1Teg's Avatar
Default clutch making noise?
when I first got my car and knew nothing about it, I had a friend at good year get me a new clutch, and put it in, but it wasn't OEM. He said it had a heavy duty pressure plate, and could take a lot of abuse(since I was knew to 5 speed as well). Being the import hater he is, he can't even remember what clutch it was, but it was $500 bucks I know that much. Well anyway, the issue is...its making a rubbing or lil screech time noise when I push it down. It did this one time before then it went away, today I noticed it feeling "notchy" as I was pushing it down. And now when its disengaged, and then I re-engage it, it squeeks but if I pump it the noise slowly drifts away, then I let it out for a few seconds, push it again, and screech. I checked the fluid, and it wasn't low at all, but I topped it off just to make sure, but even when the car wasn't running, it was makin this noise when I push the pedal down. I was thinkin its the throw out bearing...but I mean the clutch has 5,000 miles on it, and I'm pretty sure I got a new throw out bearing when I got the clutch. BTW its a 94 LS Hydro. Anybody have any ideas? thanks.
Old Apr 20, 2004 | 07:47 PM
doublejz's Avatar
Default Re: clutch making noise? (94B18B1Teg)
i would guess throwout bearing, and the notchy could be either the clutch not disengaging the whole way, or syncros
Old Apr 20, 2004 | 09:45 PM
SleepyHF's Avatar
Default Re: clutch making noise? (doublejz)
Throw out bearing for sure
Old Apr 20, 2004 | 10:08 PM
d16y8turbo's Avatar
take it apart and see if anything looks funky in there. i would guess the throughout bearking though. did he use a lot of grease on the bearing before putting it it???
Old Apr 21, 2004 | 02:51 AM
94B18B1Teg's Avatar
I was told by someone that the where the fork meets the slave cylinder, needs to be greased? they said I should grease the pivot ball there, and then spray some lithium grease towards the other end of the fork, and it should work out fine
AussieR
Sep 4, 2016 08:30 AM
kte324
Transmission & Drivetrain
15
Feb 16, 2010 09:40 PM
victor.m
Apr 4, 2009 09:19 PM
red05
Honda Civic (2001 - 2005)
Nov 2, 2007 07:41 PM
94B18B1Teg
Apr 20, 2004 03:34 PM
