Clutch install Question
Old Oct 6, 2003 | 07:24 PM
Gerst240's Avatar
Default Clutch install Question
(sorry for the shitty quality camera sucks...)
wtf is this bearing it came with an exedy clutch (pic is actual size on 1024x768)
Thanks
Old Oct 6, 2003 | 07:25 PM
Dan GSR's Avatar
Default Re: Clutch install Question (Gerst240)
goes in the flywheel
you have to remove the flywheel to install it..
Old Oct 6, 2003 | 07:28 PM
noble4ws's Avatar
what do you mean in the flywheel, can you give more info?
Old Oct 6, 2003 | 07:29 PM
Gerst240's Avatar
So where exactly does it go behind the flywheel? is it pressed into it or just sitting there?....thanks for the quick reply
Old Oct 6, 2003 | 07:37 PM
jaysonx's Avatar
If you look in the middle of your flywheel, there is a little bearing in it. This bearing replaces that one. Simply bang it out and pop in the new one
Old Oct 6, 2003 | 07:38 PM
noble4ws's Avatar
did the h23 have one also because thats where the flywheel came from
Old Oct 6, 2003 | 07:40 PM
Gerst240's Avatar
awesome thanks for the help
Old Oct 7, 2003 | 12:51 AM
muse's Avatar
Default Re: (Gerst240)
Make sure that when you re install the new bearing, you don't hit it in the "darker" area.
That could damage it severely, tap it in using a socket that is the same size as the bearing, and use the backside of the socket, not the opening side.
Old Oct 7, 2003 | 04:47 AM
pro1342's Avatar
Default Re: (muse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muse &raquo;</TD></TR><TR><TD CLASS="quote">Make sure that when you re install the new bearing, you don't hit it in the "darker" area.
That could damage it severely, tap it in using a socket that is the same size as the bearing, and use the backside of the socket, not the opening side.</TD></TR></TABLE>
Old Oct 7, 2003 | 04:17 PM
noble4ws's Avatar
did the h23 have that bearing also
Old Oct 7, 2003 | 08:04 PM
Se-rv-Tak's Avatar
Default Re: (noble4ws)
u don't ahve to remove the flywheel!
just get a bearing remover...
all the flywheels and clutch's that i have worked on u never have to remove the flywheel...
and i've pulled clutchs on hondas/domestics.. etc. etc....
it' will save u time and labor.. just get a bearning puller
Old Oct 7, 2003 | 08:17 PM
Dan GSR's Avatar
Default Re: (Soon2B18Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2B18Boost &raquo;</TD></TR><TR><TD CLASS="quote">u don't ahve to remove the flywheel!
it' will save u time and labor.. just get a bearning puller</TD></TR></TABLE>
wrong you do have to take off the flywheel
the bearing comes out from the backside of the flywheel....and must be installed the same way....it won't come out without taking the flywheel off....
Old Oct 7, 2003 | 08:41 PM
T4eg's Avatar
Default Re: Clutch install Question (Dan GSR)
pilot bearing...goes in flywheel
Old Oct 8, 2003 | 12:13 AM
Se-rv-Tak's Avatar
Default Re: Clutch install Question (BlueHatch00)
wow.... my bad... ur right.. u have to remove the flywheel.....
but it doesn't matter which way u put the bearning in.....
my mistake.
Old Oct 8, 2003 | 03:51 AM
jerseybrandon's Avatar
Default Re: (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">
the bearing comes out from the backside of the flywheel....and must be installed the same way....it won't come out without taking the flywheel off....</TD></TR></TABLE>
Yup, and that is a pilot bearing.
Old Oct 8, 2003 | 06:57 AM
pro1342's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noble4ws &raquo;</TD></TR><TR><TD CLASS="quote">did the h23 have one also because thats where the flywheel came from</TD></TR></TABLE>
No.
Old Oct 8, 2003 | 07:07 AM
psycho_civic's Avatar
what happens if u dont change it. i just installed my spec clutch and was too lazy to take off the flywheel
Old Oct 8, 2003 | 07:49 AM
Xsi's Avatar
Xsi
Default Re: (psycho_civic)
It depends how many miles you have done. You may not need to replace it but if you're going to remove your whole tranny you may as well replace a cheap bearing.
Old Oct 8, 2003 | 10:25 AM
noble4ws's Avatar
just double checking the h23 flywheel DOES NOT have a pilot bearing, so then is it ok to use the h23 flywheel on the h22, thanks for the info guys its the only thing keeping me from getting this engine together and in
Old Oct 8, 2003 | 10:28 AM
1_bad_EF's Avatar
i think the h23 uses a bronze bushing
can anyone confirm this
Old Oct 8, 2003 | 11:04 AM
noble4ws's Avatar
if it is bronze bushing what should i do
Old Oct 8, 2003 | 11:25 AM
1_bad_EF's Avatar
did you get a clutch for a h22 or h23? If you can put the pilot bearing in place of the bushing and it all fits, do it. Try to put the bearing on the input shaft of the trans first to see if it fits.
Old Oct 8, 2003 | 02:26 PM
Gerst240's Avatar
Default Re: (1_bad_EF)
We did try and see if the pilot bearing would fit on the input shaft but it didnt should we just keep the bushing?
god damn this post has been goin for way too long....
thanks guys
Old Oct 8, 2003 | 04:46 PM
noble4ws's Avatar
bump
Old Oct 8, 2003 | 06:42 PM
Audi RS4's Avatar
Lover
isn't that the pilot bearing?-/
*edit - nevermind
