clutch getting softer and softer progressivly, help?
Old Mar 31, 2005 | 03:12 PM
jdmoutkast's Avatar
Default clutch getting softer and softer progressivly, help?
hey h-t,
I've noticed my clutch getting progressivly softer and softer, does my clutch master cylinder have to with this? or the slave? whats the difference? what do i need to do? is it as simple as replacing the fluids? do i need to bleed my clutch? do these things have anything to do with my problem? is there a handy howto somewhere or can someone point me in the right direction thanks. i appreciate it
Old Mar 31, 2005 | 03:19 PM
jdmoutkast's Avatar
btw, its a hydro clutch, clutch came out of a 99 civic ex
Old Mar 31, 2005 | 03:42 PM
jdmoutkast's Avatar
BUMP
Old Mar 31, 2005 | 04:40 PM
Lord Helmet's Avatar
Default Re: clutch getting softer and softer progressivly, help? (EFoutkast)
Could be many factors: leaking clutch master cylinder, clutch line, air in the system, or the slave cylinder.
Cheapest route for you right now is to look for any apparent leakage starting from the clutch master cylinder down to the slave cylinder. After that if there's no visual leakage you can see, start bleeding the system of air and of course replace the old hydro fluid with new hydro fluid. If you want to do all this correctly I HIGHLY recommend you get a helms manual. It is the factory manual which all honda factory techincan use to fix hondas and acuras. Basically it's the bible for honda.
Old Apr 1, 2005 | 07:26 AM
jdmoutkast's Avatar
ok its gotten to a point where the car starts fine in neutral, but the clutch is so so soft now, and i cant even put it in gear to drive. anyone have a response to this?
Old Apr 1, 2005 | 12:14 PM
jdmoutkast's Avatar
Default Re: (EFoutkast)
anyone?
Old Apr 1, 2005 | 12:34 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFoutkast &raquo;</TD></TR><TR><TD CLASS="quote">... anyone have a response to this?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFoutkast &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
Well, how about this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">... look for any apparent leakage starting from the clutch master cylinder down to the slave cylinder. After that if there's no visual leakage you can see, start bleeding the system of air and of course replace the old hydro fluid with new hydro fluid...</TD></TR></TABLE>
Old Apr 1, 2005 | 04:40 PM
jdmoutkast's Avatar
appreciate it, anything else i need to know..
Old Apr 2, 2005 | 04:12 PM
jdmoutkast's Avatar
brake fluid only correct?
Old Apr 2, 2005 | 04:27 PM
h22 civic's Avatar
dot 3
PaulMc
May 18, 2014 05:04 PM
96civic turbo
Transmission & Drivetrain
Jun 5, 2010 11:09 AM
DriveSideWays
Aug 27, 2004 05:06 PM
g00se
Mar 8, 2004 06:11 PM
myhatchrips
Dec 5, 2003 07:21 AM
