clutch fluid low...
Old Feb 18, 2003 | 10:15 PM
tegasaurus's Avatar
Default clutch fluid low...
what does this mean? I opened up the cap and its down so that the little circular plug thingey was 2 or 3 mm from touching the sides... i put some more in there. Does this thing sorta just happen or is it something i should look more into?
I have an ACT XTSS and fidanza flywheel if that makes a difference.
Old Feb 18, 2003 | 10:49 PM
Lysawy's Avatar
Default Re: clutch fluid low... (tegasaurus)
Did you check for any leaks on the lines or anything.... did you bleed the system lately more deatails would help more...
Old Feb 18, 2003 | 11:17 PM
Volcom's Avatar
check the area under the dash where the pedal going through the firewall (aka clutch master cylinder) When they get old and worn out, they leak and most of the time they leak inside the car and onto the carpet. Mine did it at 100K and I replaced it myself. It's not a difficult job.
Old Feb 19, 2003 | 10:01 AM
tegasaurus's Avatar
Default Re: clutch fluid low... (Volcom)
i did notice when i was cleaning my car that there was some grease or oil stain on the carpet near the pedal. I didn't even think to relate it to that..
thanks a bunch,
ryan
Old Feb 20, 2003 | 02:09 PM
mugensport9's Avatar
COOL
Old Feb 20, 2003 | 03:51 PM
TRENDSETTLER's Avatar
yep that will do it
jlowellintegra
Nov 27, 2010 08:15 PM
david236kEG
23
Jan 28, 2009 03:34 PM
Gomdohree
Apr 24, 2008 06:20 AM
EGPHANTOM
Jun 15, 2005 12:25 PM
rufridn
Dec 15, 2004 12:29 PM
