clutch
Old Jul 10, 2003 | 03:05 PM
JONBLAZE55555's Avatar
Default clutch
i have a '94 Honda civic with a d15. I am hearing a squeaking sound every time i push in the clutch petal. It only squeaks when the car isn't moving. i listened to the squeaking sound and it sounds like it is some where around the trany. Some one help because this is really annoying.
Old Jul 10, 2003 | 03:09 PM
976's Avatar
976
New User
Default Re: clutch (JONBLAZE55555)
Pressure realease bearing is going.
Old Jul 10, 2003 | 03:27 PM
Default Re: clutch (976)
could that be why my presure point for my petal is far up?
Old Jul 10, 2003 | 03:49 PM
976's Avatar
976
New User
The reason your engagment/pressure point is high is becasue your clutch plate is worn. I bet you have at least 60K miles on the clutch?
I would recommend looking into a new clutch sometime soon.
To wear out a bearing quick you need to be a person who holds on the clutch a lot.
Make sure when you do/if get a new clutch, you have the bearing replaced and greased!
Old Jul 10, 2003 | 03:53 PM
you mean have my foot pushed down on it alot, no. could it be from slaming gears??an the clutch doesnt have many miles on it. befor i bought it off a guy he replaced the clutch. maybe he just lied
Old Jul 10, 2003 | 04:47 PM
poison's Avatar
Sounds definitely like the Throw-Out Bearing and definitely suggest replacing it.
Old Jul 10, 2003 | 05:03 PM
Default Re: clutch (poison)
don't i have to take my trans and clutch apart to do this. I've never done it or know any one who's done it
Old Jul 10, 2003 | 08:10 PM
poison's Avatar
Ya, you will have to remove the axles from the transmission, remove the starter, and remove the tranny to gain access to the bell housing.
It's pretty simple. Just a matter of time of removing bolts and such.
Old Jul 11, 2003 | 08:32 AM
where can i get 1 and what do they look like. Do you think my pressure plate on my clutch is going
Old Jul 11, 2003 | 09:16 AM
bump
Old Jul 11, 2003 | 09:28 AM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Sounds definitely like the Throw-Out Bearing and definitely suggest replacing it.</TD></TR></TABLE>
Right, sorry JONBLAZE, I ment throw out bearing...
Old Jul 11, 2003 | 11:34 AM
bump for help
Old Jul 11, 2003 | 08:24 PM
does any 1 know where to find one?
Old Jul 11, 2003 | 11:32 PM
irev210's Avatar
definitly a throwout bearing. Id inspect the clutch for wear when you take it off. Any parts store will have the throwout bearing you need. just make sure you lub your shaft w/ moly lube aswell, otherwise that can start makin noise too.
Battle Stage
Jul 10, 2013 12:50 PM
MiNeSEK
19
May 11, 2013 12:05 AM
maxboost94
Sep 20, 2007 07:40 PM
SIKING
Oct 12, 2003 05:29 PM
integra81
Mar 10, 2002 12:17 AM
