Speedo not working along with odometer
Like title says those two things arnt working, the VSS is working because my s300 shows how fast im going. I checked fuse number 15 and it was fine. Also changed out clusters with my friends whose was working and that didnt solve it. So now im stuck seems like it has to be between the ECU and cluster? i havent been able to find a wiring diagram to help me. I see the vss goes into ecu but where does it go and come from to the cluster?
Re: Speedo not working along with odometer
Cluster: Blu/Wht wire at terminal B11 of the cluster connector B.
VSS: Blu/Wht wire in VSS connector.
Is there continuity between these two points?
afterdark
13
04-30-2009 10:12 AM
USDMSiR
15
08-31-2006 02:07 PM
