cleaning carbon off the valves?
Old Aug 19, 2009 | 04:03 PM
scarney's Avatar
Default cleaning carbon off the valves?
I bought a b16 long block to use the head for my ls/vtec
on the 3rd cyl valves there is a good about of build up, The motor was smoking (rings) especially on the 3rd cyl.
is there a good method of cleaning that build up off?
Old Aug 21, 2009 | 09:25 PM
LyveMyche's Avatar
Default Re: cleaning carbon off the valves?
I know exactly what buildup you mean, I just changed the rings in my D15b7 and the valves had the same carbon like build up on them. I just used a wire wheel in a drill and went to work on them. I used a brass wire wheel so there is no chance you will damage the valves with that. Clean all up in the combustion chambers on the head with it too.
Old Aug 22, 2009 | 09:54 AM
slomofo's Avatar
GDD Member
Just four valves? They're like six bucks a pop for new valves, change them. Seriously though, take your head to a machine shop and fork out the $30.00 to have the head cleaned. While there, they'll usually tell you if anything on the head needs to be worked on (resurface, cracks, leaking valves, etc.).
Old Aug 22, 2009 | 10:32 AM
street_ride14's Avatar
OEM valves are way more than $6 per valve, Where do you buy yours ?
Old Aug 22, 2009 | 09:15 PM
LyveMyche's Avatar
I dont think you need new valves or machine work either. just wire wheel it and put that bitch back together. drive it tonight
that-guy
Apr 28, 2010 05:11 PM
lwmmuas
Feb 3, 2010 09:09 AM
DJYoshaBYD
Dec 9, 2009 10:59 AM
KooK
May 22, 2003 07:23 AM
speedymon
Mar 22, 2002 09:40 AM
