civic help
Old Jan 11, 2013 | 02:52 PM
honda2281994's Avatar
Default civic help
I have 2 qestion 1. does anyone know where the brake pedal springs connects on the steering clounm or have any pics. 2. i have a b18a1 and the throttle is loose i dont know if its connected wrong on the gas pedal or what. If anyone has some pics id appricate it need the help
Old Jan 11, 2013 | 03:07 PM
Default Re: civic help
also would the brake return spring if not hooked could that cause the brake light to stay on??????????
Old Jan 21, 2013 | 09:53 AM
electron blueSi's Avatar
If you pull the brake pedal up by hand will the brake lights go off?
Brake switches are usually adjustable. They can be screwed in or out depending on where you want the lights to come on.
As for the brake return spring, the locations where they attached should be noticeable. Look for loops and/or a small hole.
Old Jan 21, 2013 | 06:54 PM
fcm's Avatar
fcm
Old Fart
Again, the MM&Y and trim level, auto or 5 speed, would speed things up considerably.
I will have to assume, you have a 94 Civic and it's a 5 speed... #20
http://www.hondaautomotiveparts.com/...catcgry5=PEDAL
As mentioned brake switch may be adjustable if needed, it may not be making contact because of missing return spring, [lift pedal to test].
If not one of the above, brake pin switch "plug" is missing/broken. 94
Old Feb 28, 2013 | 07:35 AM
Green-Sir-Ek's Avatar
Check the tension of your throttle cable (located on your intake manifold) if it's loose you should be able to tighten it.
Mooie Telebogen
Suspension & Brakes
Jul 15, 2016 11:23 AM
Kdeezy95
11
Nov 10, 2013 10:20 PM
93grayeg
19
Sep 8, 2009 07:30 PM
_dergo_
Aug 4, 2007 12:37 PM
