Chipped Teeth for VSS on Differential?
Old Dec 23, 2007 | 11:22 AM
94 delsol's Avatar
Default Chipped Teeth for VSS on Differential?
On the differential their are the teeth that spin the vss. a couple of these teeth, for the vss, on my differential have chipped. Do you think i will have any issues with the vss getting snagged on a chipped teeth.
Here is a pic
Old Dec 25, 2007 | 05:35 AM
94 delsol's Avatar
Default Re: Chipped Teeth for VSS on Differential? (94 delsol)
bump
Old Dec 25, 2007 | 01:40 PM
aca's Avatar
aca
im pretty sure that is just the speedometer drive gear.
the question is, where did the pieces go.
you should be able to just change the gear
Old Dec 25, 2007 | 04:56 PM
hilltopgraphics's Avatar
Default Re: Chipped Teeth for VSS on Differential? (aca)
Your vss gear will eventually, if not quickly, develop a wear pattern as well. This will result in a rather profuse whine noise.
Did you damage the teeth when installing the vss? This is a very common problem. Always make sure the vss bolt flange is solid against the case spotface before running the bolt in.
soninihon
Nov 8, 2015 09:42 AM
yungmulacrx
Transmission & Drivetrain
Aug 27, 2013 12:48 PM
pleej
Aug 20, 2010 11:49 AM
THC07
Mar 27, 2008 06:39 AM
TurboSam
Oct 27, 2003 08:08 PM
