chipped ecu problem
so i have a b20/vtec with a chipped p28
i was running a kenji chip that was alright but the vtec was too high.. so i just got one from the ihatericerz dude..
i put it in and start it up.. revs to 2k with a cel.. the car is warm at this time because i had just drove home..
so im like wtf, i have 2 other chips from kenji one is for my setup and one is for my friends that i just got so he could try ( his is sohc vtec) and i got them mixed up..
1 does the same thing as the first.. and 1 revs to like 1k but if you give it gas it goes then drops down way way low and almost dies..
so could i have jacked the wiring when i swapped them or something? whats going on?
any help/thoughts/suggestions are appreciated
thanks
thanks
alright i was just messing around with it.. and i got my regular chip to run like normal, but the new chip still has a cel and idles at 2k
so is that a bad chip or what else can it be?
Modified by matman4444 at 7:29 PM 6/8/2005
so is that a bad chip or what else can it be?Modified by matman4444 at 7:29 PM 6/8/2005
you could have damaged the chip and/or ecu by putting in the chip backwards. You will notice a notch/groove on one end of the socket as well as the chip itself. They both should be pointing towards the plugs of the ecu's. Also, make sure the pins of the eprom are lining up and are firmly secure with in the socket. If one pin isnt lined up or making a direct connection, the chip will not work properly. I'm just hoping you didnt fry the chip already
andreysibiris
Jul 31, 2005 02:44 PM
schtozo
11
Feb 14, 2004 04:31 PM
