check out this b18c1 block
Old Feb 23, 2004 | 10:37 AM
dabomb's Avatar
Default check out this b18c1 block
sorry i'm not sure where to post this but theres this guy selling this block and i'm just wondering what you guys think of it? i'm looking to build up my stoke block for a turbo set up. i've never heard of ari sleeves and a block guard welded in, so i need your guys opinion.
b18c1 block
It also contains ARI ductile iron sleeves, that have been bored to 84.1mm, and are now closed deck due to the block guard welded in. This is perfect for an NA (1.9L) setup, or can be configured to a boosted setup. It also includes the main caps (and girdle) and oil squirters.
thanks for the help
Old Feb 24, 2004 | 08:06 PM
chameleon's Avatar
Default Re: check out this b18c1 block (dabomb)
sounds like a good setup, even doh the block guard was not needed if the block is really sleeved, but its a perfect platform for either NA or turbo. just gotta decide what you want to do. just make sure you get the pistons for the right bore size. good luck!
Rickcrx
Feb 23, 2012 05:18 PM
menkio
Jun 12, 2004 10:37 AM
CIVICNONVTEC
Aug 23, 2003 06:00 AM
