check engine light at WOT, tps problem?
Old Nov 3, 2002 | 04:22 PM
743power's Avatar
Default check engine light at WOT, tps problem?
I have a 95 cx with a sir2 b16a. The cx harness was modified for vtec. The probem is if the car is at WOT for more than a few seconds, the check engine light comes on. I don't remember what code it was throwing, but it was a TPS code. This CEL isn't affecting engine performance in any way, but it's getting annoying. Anybody encounter this problem before?
Old Nov 3, 2002 | 04:51 PM
creuger's Avatar
Default Re: check engine light at WOT, tps problem? (743)
i think the problem is the ajustment of the tps,if it got ajustable screws
you have to got the adjustement spec and procedure to performe it.
Old Nov 3, 2002 | 07:09 PM
743power's Avatar
Default Re: check engine light at WOT, tps problem? (creuger)
oh shoot. . . I forgot to mention that there is too much voltage reaching the tps. Basically all I need to know is what would cause this, and how do I stop it from happening?
Old Nov 3, 2002 | 07:51 PM
Sonny's Avatar
The TPS voltage should read about 0.45 volts at idle and about 4.5 volts at WOT.
Sonny
Old Nov 3, 2002 | 09:14 PM
oldirt3277's Avatar
New User
Default Re: check engine light at WOT, tps problem? (Sonny)
Iam currently having the same problem 94 ex d16z6 ,I have changed the 02 sensor ,iac motor,and it surges while idiling unless the a/c is on and then it starts irratic idiling again.When the coolant fan comes on the car runs normal.I was wondering if I should change the tps because the stock is still on the throttle body,rivveted. Help me out ,please no smart *** replys.
Old Nov 4, 2002 | 08:20 AM
743power's Avatar
I think mine is around 6 volts at WOT. . . I could be wrong about that number, but it's more than 4.5. Someone else did the check and I don't remember what they told me. So, what could cause that much voltage to reach the tps? A crossed wire?
Sonny
red_h
Oct 27, 2010 08:08 AM
hip_hop_s0ulchild
Sep 18, 2005 04:24 PM
Forrest Gump 9
Apr 26, 2005 09:05 PM
DannyITR
Jul 21, 2004 05:10 PM
yoshio006
Dec 17, 2002 06:18 PM
