check engine light problem!!!
Old Jan 10, 2002 | 06:13 PM
iluznxpnoi's Avatar
New User
Default check engine light problem!!!
i have a b20z2 in my 96 hatchback..what i have are skunk 2 manifold, ls ecu and gsr tranny...my check engine lights been on all this time..the code im kicking are: 14, 41, and 54 anyone know how to fix those..its the electric air control, primary 02 sensor, and the crankshaft speed flacuation sensor???
please help..thanx
Old Jan 10, 2002 | 09:10 PM
DR. ON POINT's Avatar
Banned
Default Re: check engine light problem!!! (iluznxpnoi)
ummm....I got no clue with the 2 sensorone...check all ur wires....code 14 is the IAC....u probably forgot to to re pin it on the ecu...gotta move it from a14 to a12...nd the other ones just re chek ur wiring....do a search...I create thread a while ack about wiring up a ls motor and there are some good repones in there....good luck
Old Jan 10, 2002 | 10:17 PM
Kataku2K3's Avatar
Default Re: check engine light problem!!! (On Point EK)
Yea i really don't know why you would be throwin a code for ur prim O2, if you are gettin a code for that and you are using ur stock civic harness it probably has something to do with the O2 sensor itself. As for the crankshaft speed fluctuation sensor and the IAC do as On Point EK said, just check the wiring. The pin will have to be relocated for the IAC, be sure that u are movin the right wire cuz the retarded DX has the rotatary style 3 pin IAC instead of the linear style with 2 pins so you only really have to use 2 wires. The CSFS pins are in the same location wether it be a DX or an LS ECU so the problem probably lies within the wiring on the DX harness and the B20's CSFS harness. Good luck
antok86
Honda Civic (2001 - 2005)
18
Apr 30, 2012 07:03 PM
jayrod7
Jan 21, 2010 01:45 PM
mtime
Dec 17, 2009 09:17 PM
greyejcoupe
Oct 3, 2009 10:48 AM
urbantrain
Apr 19, 2002 07:32 PM
