Check engine Light on. PLZ help
Well my check engine light came on yesterday so i took it to auto zone to get it hooked up to a cpu to find the problem. This is what they told me to write down and show it to someone at the Honda dealership:
P1259
Immobilizer to PCM Signal error
Does anyone know what this means?
P1259
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">wtf? did they give you a code number?
describe your car too. info info..</TD></TR></TABLE>
It looks like from a scanner and OBD2
P1259
that is the code, thats what the code looks like when its from a scanner. if you look inside a manual it will say the codes and what they mean. sorry i cant be much more help im at work and dont have any info here.
keith
keith
Just to clear it up: "P" codes are specific to OBD2...and "P1" indicates a manufacturer specific code.
And you have a totally stock 97 Ex....I thought only Teg's came equipped with immobilizers???
No, sounds like the vtec solenoid is either not connected, or is a bad solenoid.
Jump the solenoid by taking a piece of wire and putting 12v volt to the solenoid. It should click. If it does, you have a wiring problem or bad connection. If it doesn't click, then the solenoid will need to be replaced.
thehondaguru
Nov 23, 2003 07:38 AM
Other than that, it's cake.
