Check engine light
Old Nov 16, 2002 | 01:21 PM
Slow's Avatar
Default Check engine light
I have a 98 Integra (LS) and I was just driving down the highway and my check engine light came on. What does this mean? What should i do? Thanks for the help.
Old Nov 16, 2002 | 01:31 PM
Desslok's Avatar
Default Re: Check engine light (Slow)
Autozone will check it for free and tell you what the code is.
Old Nov 16, 2002 | 01:35 PM
Team 4R's Avatar
actually, i dont think autozone can do it anymore.... you'll have to check it yourself and then look it up. got repair manual?
Old Nov 16, 2002 | 04:11 PM
RollerBoy's Avatar
You probably need to bring it into the dealer to have them check it out.. There is a place where you can reset the light off but without the dealer doing the right code or whatevers.. it will just come back on in a few days.. atleast this is what i have been told by a few people....
Old Nov 16, 2002 | 04:46 PM
b19coupe's Avatar
If you don't know and don't have a friend who does, then chances are that you will need to pay somebody to check it for you. To pull the code, there is a two pin blue connector on the right side of your car, underneath the glovebox. Turn the key on and jump the connector. Your check engine light will flash; long flashes = tens, short flashes = ones.
Honda ECU Trouble Codes
( 1) Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98
Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
(2) Accord Civic CRV CRX Del Sol Odyssey Prelude
85-89 86-87 n/a 85-87 85-91 n/a n/a
Oxygen Sensor "B"
(3) Accord Civic CRV CRX Del Sol Odyssey Prelude
MAP Sensor (Manifold Absolute Pressure)
(4) Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 88-98 97-98 88-91 93-97 95-98 85-98
CKP Sensor (Crankshaft Position Sensor)
(5) Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 * 86-98 97-98 85-91 93-97 96-98 85-98
mechanical problem / disconnected piping
* exc 94-95
(6) Accord Civic CRV CRX Del Sol Odyssey Prelude
ECT Sensor (Engine Coolant Temperature)
(7) Accord Civic CRV CRX Del Sol Odyssey Prelude
TP Sensor (Throttle Position)
(8) Accord Civic CRV CRX Del Sol Odyssey Prelude
TDC Sensor (Top Dead Center)
(9*) Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98** 86-98 97-98 85-91 93-97 95-98 85-98
CYP Sensor (Cylinder)
* not a valid code for any throttle body injection Hondas
** not a valid code for V-6 engines
(10) Accord Civic CRV CRX Del Sol Odyssey Prelude
IAT Sensor (Intake Air Temperature)
(12) Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 * n/a 85-91 * n/a 95-98 85-98
EGR Lift Sensor (Exhaust Gas Recirculation)
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
(13) Accord Civic CRV CRX Del Sol Odyssey Prelude
BARO Sensor (Atmospheric Pressure)
(14) Accord Civic CRV CRX Del Sol Odyssey Prelude
88-98 88-98 97-98 88-91 93-97 95-98 88-98
IAC Valve (Idle Air Control)
(15) Accord Civic CRV CRX Del Sol Odyssey Prelude
90-95 88-95 n/a 88-91 93-95 95 88-95
Ignition Output Signal
missing or defective ignition output signal
(16) Accord Civic CRV CRX Del Sol Odyssey Prelude
Fuel Injector System
defective circuit or unplugged / defective fuel injector
(17) Accord Civic CRV CRX Del Sol Odyssey Prelude
88-98 88-98 97-98 88-91 93-97 95-97 88-98
VSS (Vehicle Speed Sensor)
(19) Accord Civic CRV CRX Del Sol Odyssey Prelude
n/a 88-95 n/a 88-91 93-97 n/a n/a
Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
(20) Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 88-98 97-98 88-91 93-97 95-98 92-98
Electrical Load Detector
(21*) Accord Civic CRV CRX Del Sol Odyssey Prelude
94-98 ** 92-95 n/a n/a 93-95 n/a 93-95
VTEC Solenoid Valve
* not a valid code if car does not have a VTEC engine
** not with V-6 engine
(22*) Accord Civic CRV CRX Del Sol Odyssey Prelude
94-98 92-98 n/a n/a 93-97 98 93-98`
VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
(23) Accord Civic CRV CRX Del Sol Odyssey Prelude
98 * 96-98 n/a n/a 94-97 n/a 92-98
KS (Knock Sensor)
* not a valid code if V-6 engine
(30) Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 * n/a n/a n/a n/a 95 92-98 *
Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
* not a valid code for 1996
(31) Accord Civic CRV CRX Del Sol Odyssey Prelude
90-95 n/a n/a n/a n/a 95 92-95
Automatic Transmission Signal "B"
(41) Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 92-98 97-98 n/a 93-97 95-98 90-98
Primary Oxygen Sensor - Heater
circuit malfunction
(43) Accord Civic CRV CRX Del Sol Odyssey Prelude
90-95 92-95 n/a n/a 93-95 95 90-95
Fuel Supply System
defective or malfunctioning fuel supply system
(45) Accord Civic CRV CRX Del Sol Odyssey Prelude
96-98 96-98 97-98 n/a 96-97 96-98 96-98
System Too Lean or Too Rich
malfunction in the fuel monitoring systems
(48) Accord Civic CRV CRX Del Sol Odyssey Prelude
98 92-98 n/a n/a n/a n/a n/a
LAF Sensor (Lean Air Fuel)
(54) Accord Civic CRV CRX Del Sol Odyssey Prelude
96 96-98 97-98 n/a 96-97 n/a n/a
CKF Sensor (Crankshaft Speed Fluctuation)
(58) Accord Civic CRV CRX Del Sol Odyssey Prelude
98 * n/a n/a n/a n/a n/a n/a
TDC Sensor 2 (Top Dead Center)
* with V-6 engine only
(61) Accord Civic CRV CRX Del Sol Odyssey Prelude
Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
(63) Accord Civic CRV CRX Del Sol Odyssey Prelude
Oxygen Sensor, Heated - Sensor 2 (Secondary)
(65) Accord Civic CRV CRX Del Sol Odyssey Prelude
Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
(67) Accord Civic CRV CRX Del Sol Odyssey Prelude
Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
(70) Accord Civic CRV CRX Del Sol Odyssey Prelude
96-98 96-98 97-98 n/a n/a 96-98 96-98
malfunction with the automatic transmission controls
(71) Accord Civic CRV CRX Del Sol Odyssey Prelude
Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
(72) Accord Civic CRV CRX Del Sol Odyssey Prelude
Cylinder 2 Misfire or a Random Misfire
(73) Accord Civic CRV CRX Del Sol Odyssey Prelude
Cylinder 3 Misfire or a Random Misfire
(74) Accord Civic CRV CRX Del Sol Odyssey Prelude
Cylinder 4 Misfire or a Random Misfire
(75) Accord Civic CRV CRX Del Sol Odyssey Prelude
Cylinder 5 Misfire or a Random Misfire
* valid code for V-6 engine only
(76) Accord Civic CRV CRX Del Sol Odyssey Prelude
98* n/a n/a n/a n/a n/a n/a
Cylinder 6 Misfire or a Random Misfire
(80) Accord Civic CRV CRX Del Sol Odyssey Prelude
96-98 96-98 n/a n/a n/a 96-98 96-98
insufficient flow detected
(86) Accord Civic CRV CRX Del Sol Odyssey Prelude
circuit range / performance problem
(90) Accord Civic CRV CRX Del Sol Odyssey Prelude
97-98 96-98 n/a n/a n/a 98 97-98
Evaporative Emission Control System
leak detected in the fuel tank area
(91) Accord Civic CRV CRX Del Sol Odyssey Prelude
96-98 96-98 n/a n/a n/a 98 97-98
Fuel Tank Pressure Sensor
low input
(92) Accord Civic CRV CRX Del Sol Odyssey Prelude
96-98 96-98 97-98 n/a 96-97 96-97 96-98
insufficient purge flow
These same codes apply to Acura vehicles.
[Modified by b19coupe, 1:56 AM 11/17/2002]
Old Nov 16, 2002 | 08:48 PM
FredoSP's Avatar
id say pull the code with the paper clip trick and then youll have something to go on, dont take it to the dealer and get raped!!
Old Nov 19, 2002 | 02:22 PM
Slow's Avatar
I checked and I got code #90 (Accord Civic CRV CRX Del Sol Odyssey Prelude 97-98 96-98 n/a n/a n/a 98 97-98 Evaporative Emission Control System leak detected in the fuel tank area) So, I unplugged the battery and the check engine light went away for about 2 days. It has now come back on. What does this mean? Thanks for your help.
Old Nov 19, 2002 | 02:46 PM
b19coupe's Avatar
If your gas cap is tight, it means you probably have a leak in the evap. system. These are not fun to troubleshoot, so you may want to enlist some professional help.
Old Nov 19, 2002 | 04:34 PM
Slow's Avatar
any other ideas?
Old Nov 19, 2002 | 05:28 PM
b19coupe's Avatar
Your problem may be covered under your Acura emissions warranty.
Old Nov 20, 2002 | 11:52 AM
Slow's Avatar
Thanks
Old Nov 20, 2002 | 06:08 PM
90da's Avatar
I work at a Honda dealership and almost everytime we get an evap leak code, it is either the evap canister or the bypass solenoid. I don't know if this would apply to a teg. ?
Old Nov 20, 2002 | 11:11 PM
94hondaLS's Avatar
go to any mechanic and ask them to scan your car because your check engine light is on. all they do is hook a scanner to your car and it spits out a code(s). and tells you what your problem is. there may be more than 1 code but you fix the first one that pops up. because it could be related to the second problem and so on. the problem could be as simple as a loose vacuum hose. hope that helps
cooltool
Aug 15, 2011 07:56 AM
ethos0518
Aug 13, 2011 07:36 AM
G. Man
12
Feb 25, 2011 06:13 PM
speed_demon018
Mar 12, 2010 06:47 AM
