Charging Problems
Old Aug 17, 2004 | 12:04 PM
98HB's Avatar
Default Charging Problems
Well I am having a hard time keeping a charge, I put in a new batery and several days later my car wont start. I get another new batery and the same thing happens. So I buy a alternator and the same thing happens, I checked all wires and fuses and everything looks good but I noticed that when I charge the batery or jump it the power is strong for about 5mins and then all my lights go dim and the car shuts off. Any suggestions.
Old Aug 17, 2004 | 12:08 PM
xEnderx's Avatar
Default Re: Charging Problems (98HB)
Have you checked the voltage drop from battery to alternator post? The symptoms you are describing are pretty in keeping with a bad wire between those two connections.
Old Aug 17, 2004 | 12:23 PM
98HB's Avatar
Default Re: Charging Problems (xEnderx)
I haven't checked the voltage because I don't have a votage meter, but I did check the wiring between those two and every thing looks ok. Any other suggestions.
Old Aug 17, 2004 | 12:28 PM
xEnderx's Avatar
Looks can be deceiving....you may have some corrosion inside the wire sheath. My advice would be to use an old school VAT40 and do a voltage drop on the alternator.
I've got a 1 volt drop between them on my car and I have some low charge issues occasionally.
Old Aug 17, 2004 | 06:59 PM
98HB's Avatar
Well today when I was looking at my wiring I noticed that my EGR block off plate wasn't Tight enough or wasn't sealing properly. So I tightened it down and jump stared the car and it seemed to hold a charge, I drove it around and it didn't die on me. I guess my next question would be can that leak that I was having be enough to throw my car into limp mode and cause the car to act the way it did?
Old Aug 18, 2004 | 05:12 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98HB &raquo;</TD></TR><TR><TD CLASS="quote">I put in a new batery and several days later my car wont start. I get another new batery and the same thing happens. So I buy a alternator and the same thing happens...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98HB &raquo;</TD></TR><TR><TD CLASS="quote">I haven't checked the voltage because I don't have a votage meter... Any other suggestions.</TD></TR></TABLE>For the price of 2 batteries & an alternator you coulda bought a pretty nice DMM...
Old Aug 18, 2004 | 08:04 AM
EE_Chris's Avatar
Default Re: Charging Problems (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">For the price of 2 batteries & an alternator you coulda bought a pretty nice DMM...</TD></TR></TABLE>
....and a Helms in order to put that newly bought DMM to use.
Honda Charging System overview and diagnosis - This info will only be useful to you IF you had a multimeter.
tekniq
Jan 17, 2014 08:15 AM
so simple
May 21, 2012 06:10 PM
BombSquad91
Feb 12, 2012 07:51 PM
kevinEJ
Dec 30, 2010 05:08 PM
SiR Kid
Nov 18, 2002 07:38 PM
