Is this an alternator issue?
Old Nov 15, 2002 | 08:12 PM
SiR Kid's Avatar
New User
Default Is this an alternator issue?
Sup all. Here's my situation.
I've relocated the battery in my 91 Si a good while ago, Just recently, I drove my car home from a friend's house and after 15 minutes or so it started to run rough, and the dash lights started to get brownish dim, like the alternbator wasn't putting out enough juice.
I've got a good Optima bettery that I jsut bought about 2 months ago, and it seems to still charge fine until I drive for 10 mintues or so, but once it's been running for a little while, and the car warms up, the lights start to dim, and the car runs rough.
Any suggestions before I blow $50 and a few hours on a brush replacement?
Old Nov 15, 2002 | 08:27 PM
Desslok's Avatar
Default Re: Is this an alternator issue? (SiR Kid)
Battery in rear? What gauge wire? check all connections.
Old Nov 15, 2002 | 09:04 PM
MrTodd's Avatar
Default Re: Is this an alternator issue? (sp)
It's definitely a loose ground. Do what sp posted above...
Old Nov 17, 2002 | 03:45 AM
PnX-R's Avatar
Yeah it's gotta be your Ground!..
Whatever... How can a do such a thing..
Your problem could be a lot of things.. But I'd check the Alternator first..
Take your Multimeter and check for Voltage at the Battery.. Is it sitting at about 13.8V to 14.8V?.. If not, it's either your output wire from the Alternator to the Battery has excessive resistance or your Alernator isn't putting out enough..
To check the Alternator, just check Voltage coming out of the Alternator.. It should read the same as at the Battery.. If not, it could be the Voltage Regulator..
Kinda busy now..
Let me know how it goes..
Old Nov 18, 2002 | 02:20 PM
SiR Kid's Avatar
New User
Default Re: Is this an alternator issue? (PnX-R)
Good info. I'm going to putt it and have a rpo take a look at it friday. Get the brushes replaced and have his test it outside the car
I'll let yah know...
Old Nov 18, 2002 | 04:42 PM
earl's Avatar
No brushes in an alternator
Old Nov 18, 2002 | 04:48 PM
Desslok's Avatar
Default Re: Is this an alternator issue? (earl)
Do you mean the armature? or arm for short?
Old Nov 18, 2002 | 05:36 PM
SiR Kid's Avatar
New User
Fine, whatever. I don't pretend to know anything about how they're made, but I'm in serious need of having mine repaired.
Old Nov 18, 2002 | 07:20 PM
Desslok's Avatar
Autozone and Pep boys will test your alternator for free.
Old Nov 18, 2002 | 07:28 PM
PnX-R's Avatar
You must be thinking about a Starter.. Starters have an Armature with Carbon Brushes riding on the Commutator bars.. Alternators have a Rotor with Carbon Brushes riding on the Slip Rings..
And please.. I don't need to pretend.. That's because I've worked hard to understand how the Starting and Charging Systems work..
Old Nov 18, 2002 | 07:38 PM
Desslok's Avatar
I thought alternators had rotors, stators, and rectifiers?
Dcmonstr_33
Jun 28, 2013 11:47 AM
stock4now
Jun 9, 2006 01:19 PM
douglaslovin
Oct 7, 2005 01:50 AM
97VtecIN
Nov 6, 2004 05:14 AM
bajazteg
Jan 30, 2003 04:09 PM
