changing wheel bearing??
Old Mar 22, 2009 | 05:45 AM
Keangdawizes's Avatar
Default changing wheel bearing??
does anyone have instruction or a write up of how to change wheel bearing for 1999 integra gsr? please help me out thank you
Old Apr 3, 2009 | 10:37 AM
Default Re: changing wheel bearing??
bump
Old Apr 3, 2009 | 09:16 PM
HondatagirlPea's Avatar
From: Between the hills of Downtown LA and Pasadena
First off all you are going to need a press, if you dont you can have your local brake or tire shop remove and press in the new bearings
remove the whole brake system from the knuckles
Place a slide hammer onto the hub and mount it down using your lug nuts and remove the hub with the tool you rented from autozone
do same for both sides.
remove Knuckles and use a press to remove the bearings and install the new bearings aswell as the hubs at the same time.(if your ever going to race this car with slicks right now would be the best time to install extended wheelstuds)
mount the knuckles back on along with all the brake system and your set to go.
Do this at your own risk.....
Old Apr 3, 2009 | 09:20 PM
sirEGhatch's Avatar
try searching
https://honda-tech.com/forums/acura-integra-6/wheel-bearing-replacement-using-hub-tamer-no-press-needed-1996133/
roterx7
30
Mar 13, 2015 05:40 AM
jaskuloski97sh
Dec 4, 2007 06:18 PM
HCJDM1
Jul 9, 2007 10:34 AM
blueDAteg
Mar 25, 2007 10:25 PM
PAID-$$$
Jul 26, 2004 08:27 AM
