Changing outer CV boots on Integra
Old Jul 2, 2002 | 09:23 PM
E Swift's Avatar
Default Changing outer CV boots on Integra
My outer boots are starting to crack, and I need to replace them asap. When disassembling the outer boot, does transmission fluid leak out at all? I have a KAAZ LSD on my car, and I have torco race oil in the transmission. I was thinking about just having a shop fix them for me, but, i don't want them draining out my transmission, only to throw in new fluid that'll screw up my LSD. I need to know if I got to buy new oil for this repair.
Old Jul 2, 2002 | 10:01 PM
mugenracer's Avatar
Default Re: Changing outer CV boots on Integra (E Swift)
to replace CV boots you do not need to drain transmission oil, i changed mine a few months ago, and luckly this time the drive did not pop out of the tranny like last time. you will however have to fill the new boot and pack the drive end with grease before putting it on, but even if you take the whole drive out of the tranny, transmission oil cant drain out.
[Modified by mugenracer, 11:02 PM 7/2/2002]
Old Jul 3, 2002 | 12:32 AM
kinesistech's Avatar
Usually I loose a littl fluid when I pull axles. Its less than a quart. You can catch it and pour it back in, no problem. Just remove the speed sensor and pour it in there.
Kid-jdm-teggy
Transmission & Drivetrain
Sep 10, 2013 08:41 PM
peekeesh
18
May 1, 2010 01:21 PM
shadohconspiracy
13
Nov 4, 2007 08:32 AM
hypeR speed
Jun 6, 2006 12:13 PM
dynamo
Sep 27, 2005 10:51 PM
