Changing the Intake manifold
Old Apr 16, 2002 | 10:01 AM
ThugLife52's Avatar
Default Changing the Intake manifold
Does anbody know where to find instructions for changing out an intake manifold? I'm putting a type r intake manifold on a b16a motor in my 2000 civic si. If anybody kwows any tricks i would appreciatee it.
Old Apr 16, 2002 | 10:31 AM
riceboy's Avatar
Default Re: Changing the Intake manifold (ThugLife52)
uhhhh, take the old one off and then you put the new one on, thats the trick
Old Apr 16, 2002 | 10:35 AM
Sonny's Avatar
25 Year Member
http://www.helmsinc.com
Sonny
Old Apr 16, 2002 | 10:59 AM
infuryum's Avatar
Default Re:
Don't forget about the bolt under the backside of the manifold to the mounting bracket. It's not easy to get to, but has to be taken off to remove the manifold. Get a new IM gasket and TB gasket. Also, make sure your sensors are transfered over and tightened down.
Also, the R manifold needs a bracket from Acura to fit in the Si, if I'm not mistaken.
And the Helms is a must-have if you work on your own car. Spring for the cash and buy it.
[Modified by integral, 1:59 PM 4/16/2002]
Old Apr 16, 2002 | 12:20 PM
Lyonel's Avatar
I did this on my 1st gen. B16a, should be quite similar. http://homepages.paradise.net.nz/asmsbm/r_iminstall.htm
meheartmycivic
Jul 20, 2009 11:35 PM
CountDracura
Mar 24, 2009 12:56 PM
jchrm80
May 13, 2007 10:25 PM
