best alignment setup... I searched but couldn't find it.
Old Apr 16, 2002 | 11:04 AM
neumonik's Avatar
Default best alignment setup... I searched but couldn't find it.
There was a post a while ago about a good camber and toe settings. I tried searching for it but can't find it.
I'm looking mainly for the toe settings front and rear. The car see some track, but is mostly street. I want pretty neutral steering. I'm pretty sure the rear toe was said to be set at 0 to .25.
Does anyone know the post or have any suggestions.
Thanks!
Old Apr 16, 2002 | 12:02 PM
Ausmith's Avatar
Default Re: best alignment setup... I searched but couldn't find it. (neumonik)
A lot of things will factor into a good street/track setting. When you say track do you mean autocross/road or drag? Also, what type of car? Swap? Tires? Sway bars? Struts/Springs?
I would reccomend close to stock settings with a tad more negative camber up front... something like -1.5degrees. Keep the toe neutral or 1/16" out in front. Keep it neutral in the rear.
Old Apr 16, 2002 | 12:11 PM
neumonik's Avatar
Default Re: best alignment setup... I searched but couldn't find it. (Ausmith)
thanks for the reply! Track == autocross. My setup is as follows:
92 civic hatch
b18c5 swap
yoko parada 205/45/17
Suspension techniques front and rear sway bars
skunk2 coilovers/agx struts
what handling and driving characteristics would I get with the front setup you mentioned?
Old Apr 16, 2002 | 12:20 PM
Ausmith's Avatar
Then what I said will work well. The toe out will help the turn-in and get the rear end moving.
Old Apr 16, 2002 | 12:24 PM
neumonik's Avatar
awesome! Thanks a lot!
Old Apr 16, 2002 | 12:48 PM
Crazydave's Avatar
1/8 out front
0 rear
max camber you can get
great for track..
but it eats your front tires
so maybe 1/16 out
[Modified by Crazydave, 9:49 PM 4/16/2002]
Old Apr 16, 2002 | 01:33 PM
Ausmith's Avatar
Default Re: best alignment setup... I searched but couldn't find it. (Crazydave)
That is true.... but he needs to drive on the street too!
I was running -3.5 degreees up front on my ITR. That baby turned like a ****, but my A520's would not last more than 10k miles...
Fast510
15
Sep 16, 2014 03:20 AM
stmotorsports
14
Jul 24, 2004 05:34 AM
TeamSlowdotOrg
30
Dec 3, 2003 06:54 PM
kefka
Mar 6, 2003 08:26 PM
Moosilla
Jan 9, 2002 06:57 PM
