Changing Gearbox Oil on B series
Old Mar 12, 2006 | 04:21 PM
Weel's Avatar
Default Changing Gearbox Oil on B series
Sorted
Old Mar 12, 2006 | 04:50 PM
postman's Avatar
Default Re: Changing Gearbox Oil on B series (NZMugenITR)
if your refering to tranny 17mm bolt to fill and 3/8 rathcet bolt to drain i believe
Old Mar 12, 2006 | 07:47 PM
JDMtype Eg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NZMugenITR &raquo;</TD></TR><TR><TD CLASS="quote">yeah but where are they</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=641177&page=6 an easier way to fill your tranny with fluid would be through the speed sensor on top of your tranny. simply take off the orange bolt holding the speed sensor and set it aside. and fill it through the hole. This way is much easier because the original fill hole is vertical making it hard to fill.
Old Mar 13, 2006 | 08:26 AM
EK79's Avatar
the tranny bolt is under the car on the tranny side it has a square hole in it and the easiest way i think to fill the tranny is through the vss ( vehicle speed sensor ) 1 bolt to remove and snake a long tube down to it and fill no mess no worries.
Old Mar 13, 2006 | 10:28 AM
JDMC-Kamel's Avatar
Default Re: Changing Gearbox Oil on B series (stoopid monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stoopid monkey &raquo;</TD></TR><TR><TD CLASS="quote">the tranny bolt is under the car on the tranny side it has a square hole in it and the easiest way i think to fill the tranny is through the vss ( vehicle speed sensor ) 1 bolt to remove and snake a long tube down to it and fill no mess no worries.</TD></TR></TABLE>
word!
dude8383
29
Mar 24, 2005 10:17 PM
nfinitecc
Dec 3, 2004 03:47 PM
hondaeg8
23
Nov 11, 2004 07:05 PM
Mackenzie
12
Oct 30, 2004 07:49 PM
dxhatch92
Mar 23, 2004 11:29 AM
