changing coolant in V6 6gen accord
Old Oct 6, 2001 | 10:24 PM
mr tl's Avatar
Default changing coolant in V6 6gen accord
hey guys
according to the service manual there are 2 drain bolts. one is the drain plug under the front bumper, the other is the drain bolt behind the cylinder block.
my question: am i able to reach the drain bolt behind the block by simply jacking up the car? or should i let the dealer do this?
thanks
(its for a 99 3.2 tl, which is close enough to a 6gen)
Old Oct 7, 2001 | 10:44 AM
fixhondas's Avatar
Default Re: changing coolant in V6 6gen accord (mr tl)
the original coolant in your 99 will be good for 5 years- why change it?
Old Oct 7, 2001 | 01:01 PM
mr tl's Avatar
Default Re: changing coolant in V6 6gen accord (fixhondas)
its a part of routine maintenance. 3yrs/72000 km
everyone i talked to said to just drain it from the drain plug (easily accessible) and pour wated until the water starts draining
i guess i'll do that
Old Oct 7, 2001 | 01:09 PM
fixhondas's Avatar
Just drain the radiator and fill it back up with Honda coolant Type 2- it is pre-mixed with demineralized water- do not add water!
Old Oct 7, 2001 | 08:39 PM
976's Avatar
976
New User
Don't forget to open your cap and oxygen lines. Otherwise it will take time to drain, and it all won't flow out!
Old Oct 8, 2001 | 01:59 PM
Mr. Choi's Avatar
New User
Default Re: changing coolant in V6 6gen accord (B21A)
Oxygen lines? anyways, the best way to keep your cooling system clean and trouble free is to jus drain whats in the radiator and fill it every year. if you do that there is no need to add chemicals to flush out all the crap that may build up inside the engine.
Rvu
Jan 29, 2010 08:15 AM
Cpt Marvel
Oct 18, 2009 10:16 AM
AtoZ
Jan 9, 2009 08:58 AM
dk127
Apr 24, 2007 09:01 AM
return_2020
14
Oct 19, 2005 09:23 PM
