cfk bypass trick
Old Mar 26, 2012 | 03:49 PM
mrsinger's Avatar
Default cfk bypass trick
I've got a 1999 ek civic that I am swapping a b18a1 into. I am running an obd2a p75 ecu and an obd2b stock engine harness. In order to perform this trick right do I need to follow what my engine harness is or by the ECU...??
heres the link http://www.ff-squad.com/technet/ckftrick.htm
anyone done this before?
Old Mar 26, 2012 | 05:50 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: cfk bypass trick
Either one should work. I'd do the jumper harness just in case you won't to put it back to stock later it'll be easier.
Old Mar 27, 2012 | 04:48 AM
mrsinger's Avatar
All of the wires on the harness are gray, so I should go buy the pins of the obd2a ecu?
beat ignition
Honda Civic (2001 - 2005)
Jan 5, 2019 09:13 AM
SCMFOX
Feb 1, 2018 05:18 AM
Torleif
10
Aug 20, 2015 05:29 AM
Camshaft
Jul 31, 2004 10:41 PM
