CEL problems
Old Oct 27, 2009 | 04:53 PM
jm95itr's Avatar
New User
Default CEL problems
Well where to start. I have a 95 GSR with a B18C1 head and a C5 bottom end. The head is fully built with cams, valve train and port and polish job. The bottom end is completely stock. I have a P28 ECU OBD1 with Hondata S100. My problem is that my car will throw a CEL every once in a while and it won’t give me a code when I jump the two wires. When the cel is on my car won’t go pass 4000 rpm and when I gets to there it sounds like I hit rev limiter and up till 4 grand it runs fine like nothing is the matter and that goes for when it’s not on as well. Do you guys have any ideas or solutions? I’m thinking it’s a tuning issue but not sure. Any help would be greatly appreciated.
Old Oct 28, 2009 | 07:48 AM
mouab18c1's Avatar
Default Re: CEL problems
are you sure your jumping your ecu correctly? sounds like my buddies car his CEL would only come on once in awhile but when i jumped his ecu i got a code 58 which was tdc sensor #2
Old Oct 28, 2009 | 07:49 AM
mouab18c1's Avatar
https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
Old Oct 28, 2009 | 01:19 PM
jm95itr's Avatar
New User
No im doing it right. Cause before it came on for a different reason and i got a code but now i get nothing...
Old Oct 29, 2009 | 07:30 AM
mouab18c1's Avatar
then check your wires.play with your sensors and see if it throws a CEL
Mac2118
Oct 19, 2014 04:27 PM
CompanyFlow
Acura TL, RL & ZDX
Oct 26, 2006 08:24 AM
liquidxEG
Feb 22, 2005 03:46 PM
splitime
Sep 6, 2002 10:21 AM
