CEL code 23 vtec spool?
Old Jul 23, 2004 | 07:08 PM
matman4444's Avatar
Default CEL code 23 vtec spool?
ok.. i have a 92 integra with a b20b block and b16a head... i was running a chipped p28 and it was fine, i traded this guy for his p72 stock.. when i put it in my car would barely start and die if you didnt give it gas.. lots of white smoke from the exhaust also... then when i put the p28 back in its doing the same ****..its throwing code 23 which is the vtec spool solinoid valve i think.. from what ive searched other people that have had this problem are only having problems with their vtec kicking in, but i cant even get my car to run properly... help me out guys! thanks
obd1
Old Jul 23, 2004 | 09:23 PM
matman4444's Avatar
Default Re: CEL code 23 vtec spool? (matman4444)
anyone anyone?
Old Jul 24, 2004 | 08:28 AM
B17AGSR's Avatar
Sounds like a problem I had when I did my LS/Vtec....The p72 might be looking for the knock sensor..........if you do not have a knock sensor, this might be the problem. Also check your oil level
Old Jul 24, 2004 | 09:45 AM
hondaguyef's Avatar
Default Re: CEL code 23 vtec spool? (B17AGSR)
You told me that it was code 21! Code 23 IS your knock sensor! If you are running the p28 there should not be a problem cause the p28 does not have a knock sensor circuit. Don't use the p72 unless you run a knock(you can put it in the alternator bracket hole) PM me w/ any more questions. Have I been helpful or what!!!
Old Jul 24, 2004 | 10:58 AM
matman4444's Avatar
Default Re: CEL code 23 vtec spool? (hondaguyef)
yes i figured that the p72 wasnt working because of the knock sensor... but not when i put my p28 back in it still wont work and code 21 is coming up.. so now what do i do? could putting the p72 in have broken something?
Old Jul 24, 2004 | 10:59 AM
matman4444's Avatar
it is code 21 not 23 that was just a typo...
but 21 is the vtec spool solenoid
Old Jul 24, 2004 | 02:25 PM
matman4444's Avatar
just from swapping ecus could it break the vtec solenoid?
Old Jul 30, 2004 | 09:20 AM
Tracy's Avatar
i am having the same problem with a b18 using a p28 ecu.
dan
Old Jul 30, 2004 | 09:30 AM
bruthaboost's Avatar
Check if the solenoid is actuall functioning. Put battery voltage on it and listen for the "click."
cadwiese
12
Dec 6, 2008 02:00 PM
C_Rock77
Feb 17, 2008 11:46 PM
Topdawgg
Aug 11, 2005 10:40 PM
kholmes
Mar 11, 2005 08:30 PM
gaydm.accord
Mar 8, 2004 03:53 PM
