cel after driving
Old Sep 15, 2003 | 02:54 AM
milanoGSR's Avatar
Default cel after driving
Ever since I got my DC 4-1 header put on I have been getting a CEL. I have also gone through a motor swap and the CEL still comes on. I didn't do the swap myself, but I have looked at all the wiring and it seems like everything is connected, but I dont know much about it.
Anyway - when driving, after the car warms up the CEL will come on randomly. Sometimes it takes longer than other times. It will come on immediately if I hit VTEC. However, its not a normal CEL, because it goes away as soon as I shut the car off. So when I start it back up again, its gone. This makes it so I can't check the code.
Has anyone had a similar problem? The car has felt kinda slow ever since. I'm wondering if its an O2 sensor problem, or something to do with the intake manifold area, or maybe the ECU is just bad. This is a brand new ECU too...about a year old.
any help would be very appreciated.
-brett
Old Sep 15, 2003 | 03:59 AM
1bad-eg's Avatar
Default Re: cel after driving (milanoGSR)
Have you tried checking for codes, cause the ecu stores the code in its memory until the code is erased.
Old Sep 15, 2003 | 05:27 AM
mr.beeks's Avatar
Default Re: cel after driving (1bad-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad-eg &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried checking for codes, cause the ecu stores the code in its memory until the code is erased.</TD></TR></TABLE>
post the code so we could help you
Old Sep 15, 2003 | 06:31 AM
milanoGSR's Avatar
Default Re: cel after driving (francisco flores)
I've tried checking, but I haven't got any codes. Maybe I'm not doing it right. Does anyone know which wires to jump on an OBD1 ecu? Would a paper clip work?
Old Sep 25, 2003 | 07:07 AM
milanoGSR's Avatar
When I get a hondata, can I tune out the check engine light?
swappedcx
Feb 16, 2006 10:38 PM
liquidxEG
Feb 22, 2005 03:46 PM
denshu
Dec 16, 2003 02:48 PM
B18EG6
Nov 8, 2002 07:22 AM
