cel 3 Map code from h3ll? HELP!
Old Apr 24, 2010 | 06:40 PM
BetterBuiltek9's Avatar
Icon2 cel 3 Map code from h3ll? HELP!
ok so i installed a tb my map was dangleing before off to the side. now on the new blox tb i bought it has a spot on top for the map to sit. so i basically threw it on top with o ring and all, now code 3 so i simply tried a new map. and no wasnt the problem. i tested the wires going to the map sensor with my digi. multi meter and i had a constant power, a ground and another power (signal) wire all reading correctly(as far as i know). ground has a bit of resistance but only .5 ohms not enough to do anything... im lost what should i look for btw no vacume leaks..
ive researched and reseached and tried all i can think of to do. thank you for the help in advance. and thanks for taking the time to help.
Old Apr 25, 2010 | 09:50 AM
Default Re: cel 3 Map code from h3ll? HELP!
anyone... i got stock pr4 ecu and chipped p28 both throw same code cel 3. .....
Old Apr 26, 2010 | 12:16 PM
Mikey3000's Avatar
i'm guessing the car doesn't run well? did u swap the tps and map connectors?
Old Apr 26, 2010 | 05:38 PM
checked connectors are placed correctly. can upgrading to a larger bore tb (68mm) and a victor x mani cause me to need a 2 bar map or something like that. again ive checked all possible vacume leakes
Old Apr 27, 2010 | 06:05 AM
Mikey3000's Avatar
no, only positive pressure due to a turbo/supercharger would make you need a different map sensor. have you tried pulling the map off of the tb and running a hose to the nipple like you had it before?
Old Apr 27, 2010 | 08:54 AM
Ya tried that and reset ecu still coding
Old Apr 27, 2010 | 03:30 PM
97ek-t's Avatar
prolly the gasket not letting the map get vaccum.. it has to have a small cut out to get vaccum from the port
Old Apr 27, 2010 | 05:44 PM
checked that got vacume at the tb where the map sits. tried map on another vacume source and that changed nothing as well. its a real stumper haha
Old Apr 28, 2010 | 04:32 AM
Mikey3000's Avatar
have you checked if there's an open wire from the ecu plug to the map plug?
Old Apr 28, 2010 | 08:30 AM
ya i followed the wire through the harnesses i cant see anything that would creat this problem so i swapped with another motor harness and still same problem. ill search for a diargram and double check everything one more time. if not its off for a diagnostics
Old May 8, 2010 | 10:51 AM
toolbox21's Avatar
yeah im having the same problem in my b16 crx, ive tried everything u have tried and i also ran 3 new wire straight form ecu to map sensor still code 3, so idk all i did is change y plugs and adjust my tps sensor, and now i got this code and it wont go away and i can drive my car with this code because it runs really rich. so if u figure it out please let me know lol. ive been battling this for 2 months now
Old May 10, 2010 | 04:10 PM
ef-hatchcrap's Avatar
bump
Old Jun 2, 2010 | 03:30 PM
Hanmin's Avatar
bump because I have the same prob lem!!
Old Jun 9, 2011 | 12:20 AM
egcoupespecial's Avatar
I have the same problem I done an engine swap d15b7 2 a b18c4 had a loada codes 21 22 41 and 3 I have cleared all them accept for 3 any help me on this? V
ok changed th02 so thats fixed hard wired the map sensor straight to the ecu cleaped the code only done this temp by strippin a small piece and connecting the wires then soldered it on now the cel code 3 is back and all the wires are in the correct location wtf ????? i honestly dont know what else to try. the car starts and idles at 1100 and no vtec ?? if i unplug the coolant temp sensor the car idles normal but no vtec i dont know what to do
also tried a diff map sensor same thing happened!!!!!!!!!!!!!
Old Jun 9, 2011 | 03:29 AM
civickiller's Avatar
Try clean your engine grounds real good
regal1975
Jun 6, 2014 08:46 AM
JDMSOHCEG
10
Sep 11, 2009 10:43 PM
solerizr
Jul 29, 2009 08:06 PM
speedooo
11
Jul 24, 2008 09:27 AM
vtec25
Oct 6, 2004 08:26 PM
