that causes oil to get dark fast?
Old Oct 28, 2005 | 11:40 PM
DriveSlowHomie's Avatar
Default that causes oil to get dark fast?
the oil in my girlfriends prelude goes really dark and thin only around 2k miles...in my integra i drive it to 3k and it dont even look half as bad as her car...what would cause this?
Old Oct 29, 2005 | 05:53 AM
mmuller's Avatar
Mad Scientist
Default Re: that causes oil to get dark fast? (cmGSR916)
dirty air filter,bad rings, unregular oil changes, ...
Old Oct 29, 2005 | 08:11 AM
rainforest's Avatar
Default Re: that causes oil to get dark fast? (mmuller)
poor quality spark plugs / poor ignition system or too much fuel can cause fuel to leak past the rings into the oil pan causing thin diluted looking oil and or darker than normal oil.
but mmuller is right about the rings and filter
Old Oct 29, 2005 | 08:55 AM
PURPLETERROR aka BIGMATT's Avatar
bad rings, cheap oil, poor state of tune
Old Oct 29, 2005 | 09:45 AM
Default Re: that causes oil to get dark fast? (PURPLETERROR aka BIGMATT)
the car is stock, everything factory, yea im thinking bad rings...it makes the oil look almost dark red, maron color, then black
Old Oct 29, 2005 | 10:20 AM
rorik's Avatar
Maroon?? never heard of that.. Check your pcv system out, #1 on my list. the pcv system pulls the blow by out of the crankcase, if it isn't working your oil can look like **** in 1k
Old Oct 29, 2005 | 02:42 PM
Takumi Fujiwara's Avatar
Default Re: (rorik)
This is part of the reason I got rid of the drain-back on the endyne breather kit. Now I just need to change my oil again and see if it stays cleaner, longer.
one8toh8
Feb 4, 2005 11:06 AM
CroSi
Aug 14, 2003 04:32 PM
wm5holla
May 19, 2003 07:30 PM
Pinpid
Dec 17, 2002 04:55 PM
jond
Jan 30, 2002 01:17 PM
