cars knocking
Old Jan 20, 2009 | 05:21 PM
v8killaz's Avatar
Default cars knocking
well i changed my freinds clutch in his car and when i was done i started it up, thinkin gall was fine, after some time the engine got a slight knock not bad at all but when i reved it to 2k it knocked like crazy so i called him and he said it was like that so i left it alone
he came back sating it was knocking bad and the heat wasnt working.
i checked his oil and there was not a drop in the engine, problem solved
so put nre oild in and start it up but the problem still exists not to my surprize
what can it be and can the heat have anything to do with it or no
or is the engine toast
btw cars a 2001-2 mr2
Old Jan 20, 2009 | 05:27 PM
quicksilver1689's Avatar
i ♥ snails
Default Re: cars knocking
you guys are dumbasses, who drives a vehicle that has a physical "knock", let alone let the engine run, your bearings and journals are prolly trashed
Old Jan 20, 2009 | 05:37 PM
v8killaz's Avatar
wait ur callin me a dumbass
ok smartass
Old Jan 20, 2009 | 05:43 PM
HamiltonRex's Avatar
agreed with above.
Drain the oil look for shavings.. check filter as well for shavings. You ran a motor with no oil, its junk.
Old Jan 20, 2009 | 06:55 PM
v8killaz's Avatar
Originally Posted by HamiltonRex
agreed with above.
ok maybe you guys need to read better
i didnt touch the oil all i did was chge the clutch and start it up and move it out the garage he drove it home, he said it was normal and the i was sitting in the car thnking it was the exhaust
then complained about the knock leter as it got worse
i never check ed the oil because i though he would know to put oil in his car
it wasnt my car
Old Jan 21, 2009 | 02:05 AM
ctr_ek209's Avatar
common since if u hear a knock check oil
Old Jan 21, 2009 | 02:16 AM
i ♥ snails
no i called you both dumb asses, ive read your posts there pretty silly.
Old Jan 21, 2009 | 05:32 AM
v8killaz's Avatar
my posts are silly
please stop speaking kid
Old Jan 21, 2009 | 05:34 AM
v8killaz's Avatar
of course and what you know when i heaRD THE KNOCK I CHECKED THE OIL
when the car was in my hands i didnt check the oil because the knock was so little that it wasnt noticable in the car
maybe outside
please dont post to to blame someone im here to find out a solution
Old Jan 21, 2009 | 05:51 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
maybe outside
if you are asking a question and bashing every you can stfu.. also, work on your English.. maybe everyone is pissed off because your English sucks so bad
Old Jan 21, 2009 | 05:52 AM
and also, what other answers do you want? the motor knocks now, it's junk.. get over it. stuff happens, build and learn
Old Jan 21, 2009 | 05:58 AM
v8killaz's Avatar
hey smartass get ur head out the hole and figure out when the bashing started
im looking for a solution, the engine is not garbage
is it hard to ask for opinions on the problem
i didnt know i had to be an english major to join this site
Old Jan 21, 2009 | 08:56 AM
mouab18c1's Avatar
answer his question and keep your dumb remarks to yourself...thats not the point of HT...and to answer your question..from my experience...my gsr did the same..when i rev it up higher then 2 grand the knock would start knocking like crazy...so i took it apart and for sure i knew already before taking it apart that i had spun a rod bearing..and i was right..so you can drain the oil and look for metal shavings or take off the oil pan and expect it...and no the heat has nothing to do with the knock
Old Jan 21, 2009 | 12:42 PM
i ♥ snails
ive read this guys posts before hes an idiot, you need to do some research, take an engine course, hell i dont know get a clue what your doing, why did you come here to ask a retarded question, do you know what causes a knock from the bottom end? if not find out, if so you should know what to do, instead of posting stupid ****, you should know to pull the oilpan and inspect the things that a knock would effect ie bearings, journals, metal shavings, ect. You ask us is the engine toast? we dont know you tell us, unless you post some pictures your the man in charge, we cant tell you much
Old Jan 21, 2009 | 02:27 PM
mmuller's Avatar
Mad Scientist
to answer your question, lack of oil will cause an engine to start knocking.. heat... not so much unless extreme to the point of oil not doing its job
Old Jan 21, 2009 | 04:56 PM
v8killaz's Avatar
ok thx guys
quicksilver i dont know what ur talking about
a knock can come from several things, not just what you stated
maybe im not as mechanically inclined as you are but i sure as hell have repect for other ht members that help me out
Old Jan 21, 2009 | 05:00 PM
v8killaz's Avatar
honda tech woudnt exist if people had no ?'s
ive helped many people out meybe you need to do the same
and repect others
ur mom never tought u to respect others huh
and even though i have as much knolege as you more opinions wont hurt
i could have figured it out but it would take longer so thats why im asking maybe someone had the exact problem than i wouldnt have take a longer route to fix it
Old Jan 21, 2009 | 07:36 PM
hey smartass get ur head out of the hole and read the first post quiksilver left.
that's as plane jane as it gets, if you start bashing people you will get bashed back, the most you could've done was ask how bearings get spun or 'trashed', the least you could've done is use the search button to figure out what can cause a knock
Old Jan 22, 2009 | 06:56 AM
mouab18c1's Avatar
enough the guy got his answer...maybe a moderator needs to lock this thread
Phsion
May 3, 2012 06:23 PM
farhan445
Nov 21, 2006 07:03 PM
96Spec Ek
Dec 23, 2005 12:17 PM
flyingduck04
Jan 20, 2004 09:23 AM
Ideal R
Jul 27, 2001 06:55 AM
