Car Wont Start! Please help.
Old Apr 8, 2009 | 09:42 AM
Leks's Avatar
Default Car Wont Start! Please help.
I have a 93 integra 4 door automatic. It turns over fine but will not start. It started twice but just died out like a second after. Here is a list of things I chook off the ecked or changed.
Checked for spark. everything good.
changed main relay
checked fuel.(took off the inlet side of the fuel filter, and cranked it) gas was flowing out.
took off all injectors and tested if they open & close. all good
tested injector pulse. everything good.
brand new battery
had the alternator tested.
took off and cleaned the throttle body.
brand new distributor
tried a different ecu
it still will not start.
If anybody has any other ideas please let me know. Im going insane!
Thankyou
Old Apr 8, 2009 | 05:08 PM
fcm's Avatar
fcm
Old Fart
Default Re: Car Wont Start! Please help.
Have you checked the timing, make sure timing belt has not "skipped" a tooth.
Have you done a fuel pressure check?94
Old Apr 8, 2009 | 06:11 PM
PyroProblem's Avatar
Try a compression check after the plugs have been removed for a while. Its possible its flooded and the rings are not sealing up...
Then id do a fuel pressure check like already mentioned. A weak fuel pump may push out a little fuel, but it may not be enough to actually start the engine...
Old Apr 8, 2009 | 07:08 PM
Leks's Avatar
ill keep you guys posted
Old Apr 8, 2009 | 08:11 PM
Leks's Avatar
just checked my timing. need some info. on the crank pulley theres 3 marks and 1 mark. the 1 mark is supposed to line up with the mark on the block right? and then the marks on each cam gear is supposed to be facing up. if this is correct then my timing is fine. i need to get a fuel pressure guage next.
Old Apr 8, 2009 | 08:13 PM
Leks's Avatar
one other thing. when I was turning the crank manually I could hear a hissing like pressure escaping. Is this normal?
Old Apr 9, 2009 | 06:06 AM
fcm's Avatar
fcm
Old Fart
The cam sprockets will have "dots" or "up" on them and a set of index marks.
The "dots" or "up" should be in the 12 o'clock position with the index marks aligned with each other.
The crankshaft sprocket has a line on it (1) it needs to be lined up with pointer on oil pump, [block].
Both the above assumes you have the #1 piston at TDC.
If timing is correct do a compression check as mentioned.
Also check for vacuum leaks. 94
Old Apr 9, 2009 | 11:21 PM
Leks's Avatar
how do i check for vacuum leaks
Old Apr 10, 2009 | 05:37 AM
fcm's Avatar
fcm
Old Fart
Start by eyeballing the vacuum lines, look for obvious cracks/damage to lines, make sure the lines are properly "plugged" in, replace dry/brittle lines. 94
Old Apr 10, 2009 | 06:00 AM
b16a1eg6's Avatar
Check your engine grounds. Thermostat housing, valve cover to body and trans to body. Just had a friends car do this. It was the thermostat ground wire, it broke off the ring terminal.
b3nma0
Honda Civic (2001 - 2005)
Aug 26, 2018 01:04 PM
jeryhawj
Jul 13, 2011 09:44 AM
neoc03
Jan 2, 2010 10:26 PM
airjordan604
Jul 3, 2009 12:24 AM
00trdtaco
Jun 3, 2008 11:30 PM
