car wont start help no fire help
Old Mar 26, 2009 | 10:22 PM
showteg's Avatar
New User
Default car wont start help no fire help
i was in my car it was running fine its a 5 speed put it in reverse and shut off wouldnt start since it turns over i can hear the fuel pump when i first turn the key pulled the plugs and no fire /spark any ideas would it be the distributor or i the main relay what do you think please help i have owned two acura ls integras but never had this problem thanksf for your time
Old Mar 27, 2009 | 06:54 AM
fcm's Avatar
fcm
Old Fart
Default Re: car wont start help no fire help
It will not be the PGM-FI Main Relay, it has nothing to do with ign. power.
First thing I would check is power to the distributor assembly, black/yellow lead should be hot in run and start.
If there is power on the black/yellow I would check the coil and ICM.
MM&Y of car would help.94
Old Apr 2, 2009 | 12:09 PM
KWayRacing's Avatar
The most likely culprit for no ignition spark is ign coil failure. You can take oil cap off and make sure camshaft is turning distributor. If cam is not turning broken Timing belt could be cause. Not likely but an easy check before anything else. Good luck
Ef4doorwagon
16
Nov 19, 2015 03:37 PM
purple ej1
Dec 27, 2008 10:47 PM
yeungkaho
Sep 21, 2007 01:17 PM
live_again_integra
Jan 4, 2007 05:42 PM
jstlsn
Oct 14, 2004 12:59 PM
