Car won't pass smog tests!
Old Oct 13, 2008 | 02:00 PM
Fast Frankie's Avatar
Default Car won't pass smog tests!
I have a 99 Civic Ex coupe, stock everything. The car was recently abandoned and the battery was completely dead as well as the radio was stolen.
The car passes the emissions test fine but will not pass the CEL/OBD system scan portion of the test. Its really annoying, I drove the car for ~ 1700 miles and the system still has not reset. What can this be? Is this the ECU?
Any help is greatly appreciated!
Old Oct 13, 2008 | 03:45 PM
anyone? any ideas
Old Oct 13, 2008 | 04:37 PM
thesmogman's Avatar
Default Re: (Fast Frankie)
Check to see if the ecu has constant power. It sounds like your ecu power is wired to the key switch which is resetting them everytime you turn off the key.
Your monitors should reset within 100 miles.
Old Oct 21, 2008 | 01:16 PM
thanks, I will try to see if I can figure it out this weekend.
team_ibR
May 27, 2010 02:53 PM
Sinology
Oct 20, 2009 03:57 PM
le0ftw
Sep 11, 2008 10:30 AM
Unlimitationz
May 6, 2005 03:20 PM
wid326
26
Aug 19, 2004 07:21 PM
