Car will not crank
Old Oct 3, 2005 | 10:14 AM
Chris22215's Avatar
Default Car will not crank
alright, I just got done building my 84mm lsvtec. I installed the turbo kit, and drove it to my house with my wideband plugged up, watching the a/f's. I had the car idleing at 14.7 rock solid. On the way home I kept it at 13.3-13.5 under normal acceleration, and 14.6-14.8 at cruise. Alright now for the strange stuff.
I got home and went to crank it the next day, and it wouldn't crank. I checked the timing, spark and fuel. it's got everything. I pulled the plugs to do a compression test. It came back 210-215 across the board. But #1,2, & 4 plugs were fouled and the piston tops were black, and #3 was clean and the piston was clean. #3 smelled like gas though. I pulled the dip stick and the oil smells a little like gas. The only thing I can think of is that my wideband needs calibrating. But I don't know. Any suggestions
Old Oct 4, 2005 | 07:25 AM
Chris22215's Avatar
Default Re: Car will not crank (Chris22215)
anyone?
Old Oct 4, 2005 | 11:15 AM
Mikey3000's Avatar
how did u do those tests if the car didnt crank?
Old Oct 4, 2005 | 12:20 PM
Chris22215's Avatar
Default Re: Car will not crank (Mikey3000)
you can smell fuel in all the cylinders, the compression test was a cold test, and for the spark just pull the plug and wire, and hold them next to a valve cover bolt. It'll arch if you have a spark.
Old Oct 4, 2005 | 10:53 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris22215 &raquo;</TD></TR><TR><TD CLASS="quote">you can smell fuel in all the cylinders, the compression test was a cold test, and for the spark just pull the plug and wire, and hold them next to a valve cover bolt. It'll arch if you have a spark.</TD></TR></TABLE>
that's not a accurate way of measuring voltage coming out of the ignition system. It doesn't tell you if it's a weak spark or strong spark. Get the right ignition spark tester instead of doing it the shade tree way.
Old Oct 5, 2005 | 05:00 AM
Chris22215's Avatar
Default Re: Car will not crank (Lord Helmet)
alright, how to I test to see if it's a strong enough spark?
lovemyhonda1
Sep 18, 2013 11:56 AM
pinecone
Jul 19, 2006 06:29 PM
standbackimapro
May 3, 2006 10:18 PM
Loveless
Mar 31, 2003 10:07 PM
hybridcrx
Jun 26, 2002 07:11 PM
