car turns over... no spark
Old Jun 15, 2003 | 10:21 AM
JDMCivicHatch93's Avatar
Default car turns over... no spark
heres the deal. i went to move my stereo and for some reason the battery wire no longer worked i checked the fuse and it was fine. so i just ran a cable from my bat. to my stereo and now it works, but then my alarm wouldnt work. so i found the fuse was burnt and replaced it. and after that i went to start my car and it turned over but wouldnt fire up.... what do you guys think happened. i checked all my fuses and the look fine. are there anyother fuses other than the ones under the dash and in the engine bay? oh and my car did start after i moved my stereo..
by the way i have an msd ignition and coil they are hookied up. the car is a 93 dx hatch with a jdm b16.
Old Jun 15, 2003 | 11:36 AM
Default Re: car turns over... no spark (JDMCivicHatch93)
ttt because any ideas will help
Old Jun 15, 2003 | 01:18 PM
Chiovnidca's Avatar
Are you getting 12 volts to the + terminal of the coil?
Old Jun 15, 2003 | 02:47 PM
Default Re: car turns over... no spark (Chiovnidca)
how can i tell? i took out a spark plug, grounded it to the block and turned my car over and nothin happen so what the frick. any other ideas???
Old Jun 15, 2003 | 04:25 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCivicHatch93 &raquo;</TD></TR><TR><TD CLASS="quote">how can i tell?</TD></TR></TABLE>
You could use a volt meter.
Modified by Chiovnidca at 9:15 PM 6/15/2003
Old Jun 15, 2003 | 05:00 PM
RedlinedVTEC's Avatar
Easiest way to check for spark is to stick a screw driver in the spark plug boot and hold it very close to, but not touching a ground. If you are not getting spark it is likely going to be your ignitor or your main relay.
Old Jun 15, 2003 | 05:02 PM
mmuller's Avatar
Mad Scientist
Default Re: car turns over... no spark (RedlinedVTEC)
check the resistance of the coil
desiromeo812
Dec 18, 2008 05:35 PM
TehMan
Feb 14, 2006 04:42 PM
Eskay@JDMCircle.com
13
Nov 6, 2004 09:38 PM
mystikteg92
Mar 17, 2004 07:55 AM
civicdan
Oct 26, 2003 04:52 PM
