car sputters in low RPM's
Old Sep 29, 2006 | 10:11 PM
LINKIN024's Avatar
Default car sputters in low RPM's
i have a 1 gen b16 in a 91 integra with a pr3 comp. when i start out and rev to 2grand it will sputter utill i get to like 3grand then it runs fine its is just low RPm's even in second or third in low rpms and i give it gas it will sputter until it gets moving please help
Old Sep 29, 2006 | 10:42 PM
MR_FIX_IT's Avatar
Default Re: car sputters in low RPM's (LINKIN024)
Any CEL,s
Old Sep 30, 2006 | 04:28 AM
Dogginator's Avatar
Daisy... Daisy...
When did you last adjust your valves? Perform a compression test.
Old Oct 3, 2006 | 12:48 PM
LINKIN024's Avatar
Default Re: car sputters in low RPM's (Dogginator)
i did a compression test befor i droped the motor in the car about two weeks ago compression was fine. timing is good spark is good hi RMS's are good just low rps's
Old Oct 3, 2006 | 01:16 PM
sysco's Avatar
im having the same problem with my ls swap into eg so please someone help!
Old Oct 4, 2006 | 10:50 PM
rhd type r's Avatar
i would recheck the timing/compression
Old Oct 5, 2006 | 05:47 PM
JDM94EG28's Avatar
Default Re: car sputters in low RPM's (rhd type r)
CHECK THE TIMING, ALSO SEE HOW YOUR ROTOR CAP IS LOOKIN LIKE AND PLUG'S
Scrapin4DR
May 5, 2008 06:33 PM
Samuels
May 26, 2007 08:34 PM
TurboJesse
Sep 23, 2003 06:20 PM
TurboJesse
10
Sep 16, 2003 05:06 PM
