Car shakes when accelerating!! HELP!!!
Old Jul 1, 2010 | 08:00 PM
yblegal's Avatar
Default Car shakes when accelerating!! HELP!!!
Just bought a 92 Integra and its in great condition, except for the fact that when I Accelerate in whatever gear (quarter-Full throttle) the car starts to vibrate and shake. Once i left off the gas it stops I checked the wheels and the balance and those are fine. I had a feeling it could be the motor mounts but im not sure. someone also told me it could be the axles. Can anyone clarify this for me, I searchd archives and didnt really come up with much. Wheres the first place I should look, how can i tell if the motor mounts are bad? any help is greatly appreciated... thanks
Old Jul 1, 2010 | 08:27 PM
TypeRMOBBiN209's Avatar
Default Re: Car shakes when accelerating!! HELP!!!
check your axles
Old Jul 1, 2010 | 08:48 PM
crazyheadrush's Avatar
Usually the oem axles have balance weights, but aftermarkets dont because they come balanced already, but ive had to swap mine out twice because it would shake on acceleration. I think its due because ur axles wiggle in motion. I would suggest just rebuilding your old ones unless they are aftermarket as well.
Old Jul 2, 2010 | 12:40 AM
SiR831's Avatar
I seen several cars with the symptoms that you described & found a groove or grooves in one of the inner cv joints.
Old Jul 2, 2010 | 06:18 AM
lsef's Avatar
Axles.
Old Jul 2, 2010 | 09:47 AM
yblegal's Avatar
Are axles From advanced auto or auto-zone safe to use, or should i just try and go back to the dealer and get them?
Old Jul 2, 2010 | 05:35 PM
Auto-zone axels dont have weights, but u can swap them as many times as u want if ur not happy with them.
Old Jul 2, 2010 | 07:33 PM
Scott_Tucker's Avatar
You sure it's not misfiring?
Old Jul 2, 2010 | 08:47 PM
wannaBjdmca6's Avatar
it happened to mine right after i swapped in autozone axles for my torn OEM ones that clicked under acceleration
Old Jul 5, 2010 | 05:36 PM
yblegal's Avatar
def. not misfiring, im gonna probably replace them next week and see what happens
Old Jul 6, 2010 | 11:39 AM
likwidchz's Avatar
I could make a stupid comment... thinking outside the box, is it possible that your missing some wheel weights?
Old Jul 6, 2010 | 12:16 PM
yblegal's Avatar
naa, I work at a tire shop so the first thing I did was rebalance all the wheels, and it still shakes...
Old Jul 6, 2010 | 12:43 PM
b18efSI's Avatar
had one at the shop today with same problem it was the axles...check them and replace them
Old Jul 7, 2010 | 01:46 PM
Dual-500's Avatar
Mine did that when the diff bearings were wasted. Check for oil leaks around seals in tranny when working the axels. Might even be worth loosening the drain plug in tranny and dripping out a little oil to check colour. If it's silvery or black I'd head for a reputable tranny shop for a look. Wheel bearings can also have similar syptoms.
This it to add to the above posts - not to contradict. Axels, first then the stuff above if they're ok. I'd check tranny oil anyway though.
Old Jul 7, 2010 | 03:26 PM
Drive 4 fun's Avatar
Had the same with one new axle, no balance weight. OEM, or Raxles. Most inexpensive axles do not have the weights. Other side has an aftermarket axle that is fine, without weight. Some places let you bring them back, but that R and R until right.
Old Dec 7, 2010 | 05:18 PM
yblegal's Avatar
well i replaced my axles, lower ball joints, and tie rods, and also rebalnced the wheels, but for some reason, the car still shakes, its not as violent as it was before, but I still feel the vibrating in 2nd and 3rd gear between 2000 and 4000 RPM. i did some research and found out it could be the half shaft or a bent subframe. Can anyone point me in the right direction?
Old Dec 18, 2010 | 05:23 PM
SQ is the SQUAD's Avatar
i had the same issue. my upper ball joints where loose and my half shalf was toast
Old Dec 21, 2010 | 09:25 AM
LTCxD2B's Avatar
When my flywheel was warped my car would shake like an earthquake wipers comin on felt like wheel hop but after my flywheel was replaced no problem only happened under slight accel or heavy in first also had this problem with a bmw the wheels would vibrate in every gear on the lift u can check this by puttin on the e brake and have some one look at ur car while u try to move forward
kito209
Sep 6, 2011 01:24 PM
wannaBjdmca6
Suspension & Brakes
Oct 16, 2010 05:25 PM
ILOVEYOURHONDA
Sep 25, 2009 08:50 PM
SlammedDC2teg
Jan 15, 2006 02:43 PM
