Car is running too cold?
Old Dec 8, 2003 | 03:00 PM
specie's Avatar
Default Car is running too cold?
Just got done replacing the head gasket. When idling the temp. is near the half way mark which is pretty normal. However, when the car starts to move and the radiator gets some air, the temp goes all the way to the Cold mark. I was thinking it might be the thermostat or the temp. sensor. I was having the same problem before replacing the head gasket. I want to fix this before having another head gasket problem. Anyone knows what the problem is?
Old Dec 8, 2003 | 03:34 PM
Kendall's Avatar
The thermostat. Change it and see what happens.
Old Dec 8, 2003 | 05:48 PM
Jimmy's Avatar
Global Moderator
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">The thermostat. Change it and see what happens.</TD></TR></TABLE>
Old Dec 8, 2003 | 09:26 PM
boostlee's Avatar
Default Re: Car is running too cold? (specie)
whats your set-up, do you have upgraded radiator??, fans??
wonder if your thermostat sensor is working correctly
http://www.cardomain.com/id/boostlee
Old Dec 11, 2003 | 06:30 PM
StorminMatt's Avatar
Default Re: Car is running too cold? (boostlee)
It sounds like your thermostat is stuck open. If it can't close (or close enough), too much water will flow through the radiator and make the engine run cold. Change that thermostat ASAP. Otherwise, you will kill your cat due to rich running (the ECU will see that the engine is cold and send it a rich 'start-up' mixture at all times) . Also, tolerances will be too loose with a cold engine, accelerating wear.
Old Dec 11, 2003 | 06:52 PM
specie's Avatar
Default Re: Car is running too cold? (StorminMatt)
stock setup.
I changed it out yesterday and it's fine now. Thanks all.
I just need to figure out the code 43, the only thing I haven't tested out is the ecu.
Old Dec 12, 2003 | 04:50 AM
JimBlake's Avatar
Reset your ECM. The 43 might be left over from when your thermostat was stuck and it ran rich.
Old Dec 12, 2003 | 03:26 PM
specie's Avatar
Default Re: Car is running too cold? (JimBlake)
reset ecu. Tried another ecu yesterday and still have code 43.
The previous owner had a A/F gauge hooked before, so I might have to check to make sure all the wires near the ecu is secured. Not sure what else there is.
Replaced fuel pump
2 O2 sensors
fuel injectors
fuel filter
fpr
Old Dec 12, 2003 | 03:40 PM
976's Avatar
976
New User
Check D14 wire on ECU pin outs.
sloassSi
Apr 16, 2010 07:15 PM
DAcraze
Acura TL, RL & ZDX
14
Dec 20, 2008 10:31 AM
marvinmark21
Jan 14, 2008 04:21 PM
scoobyghost
17
Jun 14, 2004 11:17 AM
