car only runswhen push started
Old Jan 11, 2006 | 03:02 PM
extrmeboost's Avatar
Default car only runswhen push started
I was driving my car when it just died on me. It was still running but when i pushed the gas pedal it would just kinda die out and when I came to a stop it died and would not start again. I checked for fuel and its getting plenty. I checked for spark and it wasnt appearing to get any. but when i was towing it home I put it in gear and let out the clutch it started up and ran just fine but when I pushed the gas pedal it died out on me again. I have no idea what could cause this.
setup:
95 civic cx
d16y7
po5 ecu chipped and converted running crome
cx tranny
Old Jan 11, 2006 | 05:37 PM
vteghatch's Avatar
Default Re: car only runswhen push started (extrmeboost)
was your car surging, when you turn the key the motor does crank right??
Old Jan 11, 2006 | 05:38 PM
vteghatch's Avatar
try to turn it on when its cold let me know if it turns on
Old Jan 11, 2006 | 05:57 PM
Sinner's Avatar
possible fuel filter/pump or distributor. one of those parts still works but is very weak... so you get some, but not the correct amount.
Old Jan 12, 2006 | 01:35 PM
the motor cranks just fine, it doesnt appear to be getting spark, i replaced the alternator, and checked the main relay, both seem to be good. all the fuses are good as well. I think it might be the ignitor but those are expensive as hell.
Old Jan 12, 2006 | 01:40 PM
Rtype16's Avatar
Default Re: (extrmeboost)
It doesn't appear to be getting spark or it isn't? Take the car out of gear. Unplug the injectors. Pull the spark plug wires and stick a spark plug in them. Ground the spark plug and turn the car over. Are you getting spark?
Check your TPS sensor.
Old Jan 12, 2006 | 05:35 PM
HYBRID_H@TCH's Avatar
Default Re: (Rtype16)
sounds like a weak coil..
Old Jan 12, 2006 | 05:43 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: (99Hybrid_Hatch)
did you check the rotor?
Old Jan 14, 2006 | 01:08 PM
Default Re: (2FAST4U831)
i replaced the ignitor and the rotor, the cap is good, but still no spark so i guess ill be buying a coil today.
Old Jan 15, 2006 | 08:47 AM
djnikko's Avatar
Alternator prehaps? or low fuel
Old Jan 15, 2006 | 04:55 PM
vteghatch's Avatar
it does sound like a coil problem usually when coils go out the car turns off running and when ignitors go bad once you turn the car off it wont start
ttcheung97
Aug 24, 2020 06:31 AM
90CivicDaily
22
Oct 31, 2008 03:27 PM
zennx2k3
Sep 23, 2008 05:38 AM
WanaBeFaster
Nov 13, 2007 06:32 AM
extrmeboost
13
Jan 14, 2006 01:10 PM
