car down 30 whp???
Old Apr 21, 2004 | 10:53 AM
slowestcarever's Avatar
Default car down 30 whp???
I went to the dyno a couple of months ago and dynoed my ls/vtec setup at 185whp which i felt was low to begin with. I returned to the dyno yesterday and the car was dynoed at 155 and got lower after every run....the first thing to come to mind was i blew the motor or bent valves so we did a compression test which was 220 across the board, and leakdown was below normal amounts allowed. my tuner is great and knows his stuff in and out, and air fuel was dead on nothing else was touched. what could cause this? we think its electrical(Distributor or msd) but i wanna get some more input before i rip out my msd box...
my mods are:
ls/vtec
type r pistons
ported b16 head
skunk2 stage 2 cams , springs , retainers
type r manifold
3" aem intake
dc jdm 4-1( running open header)
hondata
msd digital 6 and external coil.
everything on the motor has under 3,000 miles on it and the car is not daily driven so any input at all will be greatly appreciated.
Old Apr 21, 2004 | 12:12 PM
spaceman's Avatar
Default Re: car down 30 whp??? (slowestcarever)
probably electrical somewhere,got good grounds?alterantor good?fuel filter good?
Old Apr 21, 2004 | 12:18 PM
everyone thinks it electrical but i dunno what ...if the msd is bad i think it just wouldn't work period, but i'm not sure...everything on the motor is brand new cams ,springs ,retainers, valves, guides seals, rings everything....the motor test were perfect so i doubt its mechanical its gotta be someting in the ignition system.
Modified by slowestcarever at 11:06 PM 4/21/2004
Old Apr 21, 2004 | 01:55 PM
Rtype16's Avatar
Default Re: (slowestcarever)
SOunds like everything in the motor is fine even electrical. If something were wrong it would show up in the A/F ratio. Does the car sound like it is misfiring. If not it is probably not electrical. What you may want to do is pull the valve cover and check to see if the cams went flat. That would definately loose power.
Old Apr 21, 2004 | 04:11 PM
spaceman's Avatar
did you go to the same dyno?was the weather the same both times?did you change anything in between both runs like,wheels,bolt ons,anything?
Old Apr 22, 2004 | 05:35 AM
TurboLude97's Avatar
Default Re: car down 30 whp??? (spaceman)
check the cat.... mine was melted shut and majorly restricting air flow... i took it off and gained 40 hp.
Old Apr 22, 2004 | 05:56 AM
b18c1civic95's Avatar
Default Re: car down 30 whp??? (TurboLude97)
how's it feel when yur driving under acceleration does it come out of a bog then go...?? plugs look good?? You'd be amazed what could go bad in a distributor. But did the tuner help you check it out first then tell you its the dizzy maybe or was that his first instinct??
Old Apr 22, 2004 | 07:01 AM
TGUNNER's Avatar
I would put all of your stock ignition componants back in. They are more than fine. I went throught the enire MSD ignition external coil phase it all looks cool when you open your hood but truth is there is nothng better than OEM. Stock cap, rotor, coil and wires, can't beatem!!
It does not take long to change, try it out.
Old Apr 22, 2004 | 12:44 PM
whare is the cheapest place to get the oem parts online and do u think a bad ignitor could cause this?
Old Apr 22, 2004 | 02:04 PM
spaceman's Avatar
i dunno and yes
Old Apr 22, 2004 | 02:11 PM
Slow_Em1's Avatar
its probably the Dyno itself. thos ethings need to be re-calibrated AT LEAST every 3 days.
GoodLuck
well unless you didnt tell us something, like the car bogs out everywhere, or ticks.
Old Apr 23, 2004 | 05:54 AM
thats the weirdest part, the car doesn't feel any slower or do anything else weird for that matter....i know the butt dyno is not accurate but surely you would feel 30whp
Old Apr 23, 2004 | 06:28 AM
showtymers619's Avatar
* B A N N E D *
you would feel 30 hp.. thats like vtec not coming on, ignitor wouldnt do that.. your car just wouldnt start...try .. majestic honda
Old Apr 23, 2004 | 11:07 AM
Jimmy's Avatar
Global Moderator
..i dont think its low..
thats b-series for ya
Old Apr 23, 2004 | 12:48 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (Usdmdc2)
https://honda-tech.com/zerothread?id=838421
Got low numbers on dyno also... LSVTEC
Old Apr 23, 2004 | 03:01 PM
xplanetearth420x's Avatar
Default Re: (LSVTEC 91 Civic)
have you added ir taken anything or switch anything sense your last dyno?
Old Apr 23, 2004 | 05:04 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowestcarever &raquo;</TD></TR><TR><TD CLASS="quote">dc jdm 4-1( running open header)</TD></TR></TABLE>
Running open header will take away high RPM HP, but will give you extra low RPM torque... I'd go with a non restrictive 2.5" - 2.75" exhaust system.
JDMInteg96
Jan 11, 2009 05:02 PM
CCD-R
48
Feb 15, 2008 04:24 PM
97Alex
11
Jul 27, 2006 01:48 PM
slowestcarever
32
May 2, 2004 09:00 AM
