Help!! Motor bogs engaging vtec
Motor worked fine before and all of a sudden it's bogging when i hit vtec. Tried swapping ecu and vtec solenoid and problem still occured. adjusted the tps sensor and also the timing which was off by a lil and still happened. But when i unplug the vtec solenoid motor will go up 8k rpm fine but throws a check engine light. Any help would be appreciated.
ive experienced problems with vtec when i had too low oil and then most recently the car felt like there was no vtec without bogging and oil might have been slightly low but not super low. I topped off oil and drove for a while and it felt fine after.
If you swap the solenoid you would still need to reset the ecu to be sure right?
thanks guys i've checked the screen on the solenoid it was fine, used a friends solenoid and still the same we checked the oil level plenty of time.. im on the mark on the dipstick the full mark. i also tried swapping injectors out cause someone told me to try that and that didnt help at all..
