Car backfiring through the intake???
Old Aug 5, 2003 | 12:03 PM
EGRhatch's Avatar
Default Car backfiring through the intake???
I was just talking to my friend and he dropped in an accord ex motor in his 93 accord last week... he says that its backfiring through the intake. He thinks the timing is backwards or something... He said that he, "thinks the intake valves are kicking in before the exhaust valves so its trying to kick out the intake".
he put a new distributor in and ur supposed to turn the little rotor inside the cap to the number one cylinder and he thinks it may have been at number 4... maybe the timing sequence is off.
Can some please help us out???
Thanks a lot
Old Aug 5, 2003 | 02:30 PM
HONDADNA's Avatar
Default Re: Car backfiring through the intake??? (EGRhatch)
honda distributor will only allow you to install it one way.
did he by any chance change his timing belt before the sway?
Old Aug 5, 2003 | 02:31 PM
99_SH's Avatar
Sounds like the intake cam has its cam timing off.
Old Aug 5, 2003 | 02:42 PM
EGRhatch's Avatar
Default Re: Car backfiring through the intake??? (HONDADNA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">honda distributor will only allow you to install it one way.
did he by any chance change his timing belt before the sway?</TD></TR></TABLE>
Yes he did change the timing belt... Im guessing this is the problem?? Just need to adjust it? Thanks a lot
Old Aug 5, 2003 | 08:11 PM
EGRhatch's Avatar
any other suggestions?? looking for any possible reasons to check before we take it to the shop tomorrow!
Thanks guys
Old Aug 5, 2003 | 08:34 PM
_Endless_'s Avatar
i read somewhere before that back fire through the exhaust is cause by rich mixture while through the intake is lean but i forgot if these parameters only applies to acceleration or decelaration. i'm quite sure though that backfire through the exhaust during decceleration is caused by a rich mixture.
Old Aug 5, 2003 | 09:49 PM
T4eg's Avatar
Default Re: Car backfiring through the intake??? (_Endless_)
Id check the cam gears and make sure its not 1 tooth off
Old Aug 5, 2003 | 10:53 PM
EGRhatch's Avatar
Default Re: Car backfiring through the intake??? (BlueHatch00)
Thanks for all of your replies guys!!
I really appreciate it
Old Aug 5, 2003 | 11:00 PM
mmuller's Avatar
Mad Scientist
cam timming or dizzy is 180 out(if it is aftermarket it can be installed wrong)or dizzy is broken
DUNKLEYMOTERSPORTS90T
Jun 14, 2007 09:44 PM
juniestyle
Apr 24, 2006 09:53 PM
mrlover
Dec 10, 2005 01:19 PM
Slider89
14
Feb 2, 2005 04:08 AM
