cap and rotor
Old Dec 20, 2002 | 07:32 AM
dip-set's Avatar
Default cap and rotor
is there anything i should know before replacing my cap and rotor...second whats the best way to get the screw to remove the rotor lined up in the position to remove it....(96 integra se)
Old Dec 20, 2002 | 07:38 AM
1bad-eg's Avatar
Default Re: cap and rotor (teg-your-it)
1. Make sure you get the right cap+rotor. I recommend getting oem parts. Alot of aftermarket parts are not that great.
2. To line up the rotor, you can get a deep 19 mm socket and rachet and turn the crank pulley.
Old Dec 20, 2002 | 07:43 AM
dip-set's Avatar
Default Re: cap and rotor (1bad-eg)
i ordered the bosch cap and rotor with ngk plugs and wires...bosch fuel filter and k&n air filter drop in....sound good for a decent tune up?
Old Dec 20, 2002 | 07:58 AM
1bad-eg's Avatar
Yeah. You should be good to go.
Brett
Oct 24, 2007 07:55 PM
highneo
Mar 7, 2007 09:22 PM
hotdoggies
Jan 27, 2006 12:08 AM
dip-set
Feb 13, 2003 01:51 PM
totaled
Jan 23, 2003 11:54 AM
