cant get the pulley on the crank off...
Old Dec 8, 2002 | 11:22 AM
wizzards581's Avatar
Default cant get the pulley on the crank off...
anyone know any other ways??? the crank spins while u turn...
Old Dec 8, 2002 | 11:36 AM
youngkow's Avatar
Default Re: cant get the pulley on the crank off... (wizzards581)
You have to get a crank pulley tool made by moroso from summit, and a really long extension to you breaker bar. I'm talking about 4 ft long. Also if the engine is in the car, try putting the car in 5th gear, and have some one step on the brakes while you loosen the bolt. Good luck.
Old Dec 8, 2002 | 11:41 AM
Kataku2K3's Avatar
Default Re: cant get the pulley on the crank off... (youngkow)
You can do this... I just use an impact gun but if you don't have one... I just remove the flywheel access plate... bolt a metal bracket cut out of a 12" strip of aluminum with 2 holes drilled in it to the flywheel and to the rear side of the tranny housing... Basically the side that faces the t-belt... This will lock the crank and you should be able to get it with a breaker bar... Latez
Old Dec 8, 2002 | 04:11 PM
Default Re: cant get the pulley on the crank off... (JDMspecEG6)
my manual saids to use the flywheel.. but do u have a pic where i can see?
Old Dec 8, 2002 | 04:58 PM
Kataku2K3's Avatar
Umm... I'll try to find one but if i can't then i'll have to wait till i go home on Wednesday to take a pic... Latez
Old Dec 8, 2002 | 06:06 PM
tinkerbell's Avatar
correction, the manual says DO A SEARCH:
using the term "crank pulley bolt" in the 'archives'...
you will find a multitude of responses and many wacky ways of removing the bolt...
t..
1 sLoW hAtCh
Jun 1, 2008 10:07 AM
PreludePhill
Sep 9, 2007 11:06 PM
xrocket21
Jun 4, 2003 04:35 PM
BoostedED9
Jun 16, 2002 06:45 AM
