CANT GET IN GEARRRRRR. >=/
Old Jan 17, 2008 | 07:51 AM
VTEC_CHiCK's Avatar
Default CANT GET IN GEARRRRRR; 93civichatch. >=/
hey guys... i drive a 93 civic hatch and was wondering if you guys could tell me some possible "problems" thats going on with my car.....
sooooo. i started the car last night... tried to get it in gear and it wouldn't let me. i pressed on the clutch and it wasnt biting and had no pressure for crap.. a friend told me that the clutch is dead... another told me that its the slave cylinder? could you guys help me out a lil bit; i need to know if i need to buy a new clutch.. im ready to get one tomorrow, but i need to know if thats really the problem and the ONLY problem.
=D
Modified by VTEC_CHiCK at 12:40 PM 1/17/2008
Modified by VTEC_CHiCK at 12:51 PM 1/17/2008
Old Jan 17, 2008 | 08:13 AM
polishedturd's Avatar
I like PIE
Default Re: CANT GET IN GEARRRRRR. >=/ (VTEC_CHiCK)
its really like throwing darts in a dark room unless the car is in front of me but if you can get someone to press on the clutch while you feel the shift fork to see if its moving and if it moves its more than likely a bad clutch. you can also unbolt the slave cylinder and again have someone press the clutch to make sure its moving.
there are too many different things it can be.
my suggestion is to get the new clutch kit cause it should come with a disk, PP and a throwout bearing. then if its still the same problem master and slave cylinder kits are not that expensive nor are they very difficult to install yourself
Old Jan 17, 2008 | 08:41 AM
VTEC_CHiCK's Avatar
thanks for the reply! =]
anymore suggestions/opinions? =/
Old Jan 17, 2008 | 08:48 AM
Hondatuner88's Avatar
Default Re: (VTEC_CHiCK)
Chk your PM
Old Jan 17, 2008 | 08:49 AM
VTEC_CHiCK's Avatar
i cant, popups are blocked at work. ive been tryna unblock it since last week. hah. =D i'll check it later on today =] thanks
Old Jan 17, 2008 | 09:10 AM
SuzukaBlueAP2's Avatar
Default Re: CANT GET IN GEARRRRRR; 93civichatch. >=/ (VTEC_CHiCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_CHiCK &raquo;</TD></TR><TR><TD CLASS="quote">
what do you mean 'not biting'? My clutch never bit me.
If it doesn't have pressure the first place you should look is in the master cylinder to make sure there is enough fluid. If there is, then your slave cylinder may not be working.
If there is pressure and the clutch pedal comes back to you but it still is hard to get into gear, you have have a broken clutch disc.
Old Jan 17, 2008 | 09:13 AM
VTEC_CHiCK's Avatar
Default Re: CANT GET IN GEARRRRRR; 93civichatch. >=/ (SuzukaBlueAP2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">
haha. thanks.
Old Jan 18, 2008 | 04:55 PM
real_slow_EM1's Avatar
i think it could be ur clutch master cylinder. theres a reservoir next to your brake master reservoir that holds brake fluid. if its empty it could be causing ur slave cylinder to not engage. also this cold chicago weather makes the trans fluid really thick and a real pain to get into gear
Old Jan 18, 2008 | 07:22 PM
VTEC_CHiCK's Avatar
Default Re: CANT GET IN GEARRRRRR; 93civichatch. >=/ (real_slow_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by real_slow_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">i think it could be ur clutch master cylinder. theres a reservoir next to your brake master reservoir that holds brake fluid. if its empty it could be causing ur slave cylinder to not engage. also this cold chicago weather makes the trans fluid really thick and a real pain to get into gear</TD></TR></TABLE>
lol i actually thought about my clutch reservoir while i was at work yesterday.. i was like shiiiiiiit, i didn't check before i got towed home. (the first thing i thought of was, fkc... my clutch is fkn goneeeee. ) so when i got home yesterday... i checked and its completely empty!! i felt stupid.
thanks for the help
Old Jan 19, 2008 | 08:56 AM
I like PIE
there has to be a reason it is empty so check under your dash and on the firewall where the MC is for leaks too
Old Jan 20, 2008 | 08:24 PM
emissionsux's Avatar
Now just need to see where it's leaking from. Can you tell if the fluid is leaking out of the master cylinder? Make sure the slave cylinder is still good also. It's kinda cold to do it now, I hope it's not your daily.
GreatShamanGT
Transmission & Drivetrain
Feb 17, 2014 08:14 AM
Ej8_KiD
Mar 4, 2010 09:54 PM
integnewb
Mar 17, 2006 12:18 PM
hatchsi0485
Nov 21, 2005 06:13 AM
Polish_dude
Aug 25, 2005 02:04 AM
