cant figure out check engine light... (crx)
Old Jul 30, 2006 | 02:22 AM
mr shaun's Avatar
Default cant figure out check engine light... (crx)
just bought an 88 crx si... it has a d15b2 out of a dx in it with the si intake manifold (and fuel injection system too i guess there is a difference?)
anyways when i bought it it ran like crap, especially when cold. threw a CEL. the light on the floor says code 1, o2 sensor. i replaced the o2 sensor, it still ran like crap. i replace the plugs and cap, the wires were fine (7k ohms) now the car runs like a dream.
the check engine light still comes on though even though the car runs good. it only turns on as soon as the fan comes on when the car is up to temperature.
any ideas?
thanks, shaun
Old Jul 30, 2006 | 05:26 AM
Chiovnidca's Avatar
Default Re: cant figure out check engine light... (mr shaun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr shaun &raquo;</TD></TR><TR><TD CLASS="quote">
any ideas?
thanks, shaun</TD></TR></TABLE>
What trouble code?
Old Jul 30, 2006 | 09:49 AM
zccr-xsi's Avatar
https://honda-tech.com/zerothread?id=468260
have fun!
Old Jul 30, 2006 | 11:19 AM
mr shaun's Avatar
it is still giving me code 1, only when the fan turns on. i have already done all those diagnostics, all it leaves is the ECU to be bad... but could it be with the car running as well as it is?
Old Jul 30, 2006 | 11:29 AM
Chiovnidca's Avatar
Default Re: (mr shaun)
Does the voltage output of the o2 sensor change when the fan kicks on?
Old Jul 30, 2006 | 12:06 PM
jeremydde's Avatar
Default Re: (Chiovnidca)
Check your plugs to see if you have a lean condition, if so then inspect/replace fuel filter and or fuel pump.
Old Jul 30, 2006 | 02:01 PM
zccr-xsi's Avatar
no i heaer if your ecu is bad the red light will come on and stay on.but i never seen it do that so i dont know?
bugster
Mar 2, 2007 06:14 PM
88crxhfb16
14
Sep 25, 2006 12:30 PM
92integraVTECgsr
Sep 18, 2005 11:31 AM
SiShane
Sep 4, 2004 04:48 AM
Arsenal
Sep 3, 2003 05:33 AM
