can vtec be not working
Old Nov 13, 2002 | 09:03 AM
skierGT's Avatar
Default can vtec be not working
I just bought a 94 civic EX sohc vtec and my friend has a gsr integra. When his vtec kicks in you can feel it pullin and hear it. Mine has a slight change in sound but doesn't pull anything like the Gsr. I know my car is alot less engine but is it possible that the vtec isn't engaging?
Old Nov 13, 2002 | 09:07 AM
jeddy0120's Avatar
Default Re: can vtec be not working (skierGT)
i doubt it, that is the same thing in mine i have an ex and my friend has a gsr and u can hear it much better in the gsr. I believe it has to do with ours being an SOHC and the gsr motor being the DOHC. What kind of mods does ur friend have? plus u have to incorporate the hp difference as well.
[Modified by jeddy0120, 6:08 PM 11/13/2002]
Old Nov 13, 2002 | 09:09 AM
skierGT's Avatar
Default Re: can vtec be not working (jeddy0120)
my friends only got a cold air and exhaust
Old Nov 13, 2002 | 09:16 AM
Lord Quaalard's Avatar
I had an EX for a while, what you are experiencing is normal. It will pull slightly harder up top but you will barely be able to hear the VTEC engage.
Old Nov 13, 2002 | 09:17 AM
skierGT's Avatar
Default Re: can vtec be not working (MrDyrten)
cool thanx i was just wonderin
Old Nov 13, 2002 | 09:20 AM
jeddy0120's Avatar
same with my friend and i cant believe the difference in pull from my car. The SOHC is different b/c in our car u have one cam that has to act when we are driving aggressive and just driving around town as apposed to 2 in the DOHC.
So if u get a new cam in a SOHC and u tune it too much u have problems idling, they tend to idle rough but with the DOHC they can have one aggressive cam and one cam for just reg driving.
Old Nov 13, 2002 | 09:27 AM
Hondasaurs's Avatar
The SOHC Vtec is 127 hp compared to the 170hp of the GSR which is DOHC.
Old Nov 13, 2002 | 09:33 AM
skierGT's Avatar
would a new cam make a big difference in power?
Old Nov 13, 2002 | 09:40 AM
Hondasaurs's Avatar
Yes, its very noticeable. My buddy has a JG cam. The Vtec kicking in is more distinct and noticeable.
Old Nov 13, 2002 | 09:46 AM
Desslok's Avatar
I would get a adjustable cam gear, it made a big difference on mine.
Old Nov 13, 2002 | 09:49 AM
seano's Avatar
uhhh, no. DOHC still only has one cam for the intake side, that includes the normal and aggresive(VTEC) cam lobes. But, you are right about DOHC being hella better than SOHC, and I'm not one of the biased guys, I've owned both.
DOHC owns joO
Old Nov 13, 2002 | 11:13 AM
Default Re: can vtec be not working (sp)
What did you end up putting your timing at?
Old Nov 13, 2002 | 11:47 AM
jeddy0120's Avatar
yeah it would u just have to tune it right!
Old Nov 13, 2002 | 12:03 PM
ricodemus's Avatar
Don't forget that the GSR has the dual butterfly system which also could cause a change in pitch. but yeah, there is definitely a difference when talking audible vtec between SOHC and DOHC.
Old Nov 13, 2002 | 01:16 PM
Kamin's Avatar
COMPLETLEY POINTLESS on a SOHC motor.
dont waste the money.
the same thing can be accomplished with advancing/retarding the ignition timing.
lrcrx90
Mar 29, 2007 10:41 AM
matraca112
Sep 7, 2004 10:36 PM
GreenEX
Feb 19, 2004 06:59 PM
uranazo
39
Nov 11, 2003 04:17 AM
EK22Tim
Feb 9, 2003 08:56 AM
